20 Most Recent
Nokia X2-01 RED,BLUETOOTH,FM,QWERTY Unlocked Quadband GSM Cell Phone Questions & Answers
Nokia105
Hi if you are looking for network unlock code to unlock your Nokia 105 mobile from network lock .Then visit sites like
MobileUnlockSolutions.com they are rendering network unlock code for all mobile models at reliable cost ....
Will you help to unlock my Nokia's PUK?
For PUK codes you need to contact your service provider for your sim card! Call the customer care,am sure they will assist you the the correct PUK number..hope this is helpful
Nokia x2 01
First remove the sd memory card from your device then try to ON, if prob still same, then you should re-install the software of your device from Nokia care center
Nokia x2 01
You can format your Nokia X2-01 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YES
IMPORTANT!
Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings.
Puk code blocked
You can have PUK2 code. Call customer care, they will provide you.
Free Phone Unlocking Codes
You mean the network unlock code?I was not able to get a free unlock for the mobile model that you have specified.I suggest you can approach
Unlocking4u.com and specify the country,locked network.Based on the availability you can get the unlcok code along with free instructions for your Nokia X2-01.
