20 Most Recent Macally iBall Trackball Questions & Answers
2answers
My pendrive is write protected how to format it
my pendrive is write protected how to format it ,it says that the disk is write protected and i can read the content in it but cant delete the contents what should i do to remove the problem--ATUL
6/28/2016 6:32:31 AM • Macally iBall... • Answered on Jun 28, 2016
I cant able to format my iball cordial 8gb
Throw it away then.
8/20/2013 5:31:26 PM • Macally iBall... • Answered on Aug 20, 2013
My iball pen drive is write protected i want to format it
I believe that if it is write protected then you should be able to un-write protect it by right clicking it and finding the write protection feature and turn it off. But this may not be what is causing it or may not even have that option but from what I am thinking is there is something that has happened is you may have somehow write protected it not knowing you did and by accident. It would help if I knew the manufacturer and the model and the size so I could research it and find the exact fix for the problem.Thanks, Cody
9/12/2012 9:39:09 AM • Macally iBall... • Answered on Sep 12, 2012
3answers
This seems to be the problem of most of us these days and some of our readers who wanted to know the methods how they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
4/4/2012 4:32:15 AM • Macally iBall... • Answered on Apr 04, 2012
i use the i ball pen drive but this pen drive write protected
so i remove write pritection
4/25/2011 9:16:04 AM • Macally iBall... • Answered on Apr 25, 2011
Pen drive not format problem(the
Well this is a problem that is quite frequent, so i could explain all the various solutions and it would not cover them all so i will just post links that explain it for me, try them all one of them should work the first are guides, the last 2 links are programs designed to fix it. http://www.usbman.com/USB_Guides.htm
http://www.techspot.com/vb/topic45834.html
http://www.techspot.com/vb/topic116346.html#post687891
or Check for a tiny switch on the flash drive, some have this Confirm it is not in the Write protect position
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
4.
The following entails editing the Registry
[COLOR="DimGray"]warning:[/COLOR] If you are not comfortable in doing this, or inexperienced with the registry, then don't do it ! Incorrectly modifying the registry can have drastic effects on your system.
Start->Run-> Regedit
Expand: HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlStorageDevicePolicies
(Note: if this key doesn't exist, then disregard this option, and close Regedit)
Double click on the string 'WriteProtect' and change the 'Value Data' box to '0'
Close Regedit, and Restart
Try searching other problem first as this problem is quite common, if none of this works, you'll need to take it back to the retailer because it is broken, this is quite common too.
Please rate
Nik
1/28/2011 12:27:14 PM • Macally iBall... • Answered on Jan 28, 2011
If you mean a USB storage device then by "pen drive" then go to computer, right click on it, choose format, then leave everything as default, name what you like, and select quick format.
Note: This will destroy all data on the drive. Please make sure you have backed up everything you want to keep.
Nik
1/28/2011 8:35:19 AM • Macally iBall... • Answered on Jan 28, 2011
How can i remove write protection from my iball
to remove write protection:
open start menu>> run, type regedit and press enter, this will open the registry editor.
navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevisePolicies
double click the key WRITE PROTECT in the right pane and set the value to 0
in the value data box press ok
exit registry, restart computer, then reconnect pin drive
12/19/2010 6:41:34 AM • Macally iBall... • Answered on Dec 19, 2010
THERE IS WRITE PROTECTION IN
write protection from my iball pen drive
12/19/2010 6:11:40 AM • Macally iBall... • Answered on Dec 19, 2010
My I ball pendrive is
make sure its not locked
11/3/2010 4:44:16 AM • Macally iBall... • Answered on Nov 03, 2010
My macally icemousejr. quits working,
Thank you for the detailed description of the issue.
As you said that the light goes off on the mouse, it is loosing power.
I suspect it is the mouse going bad.
Since both the USB ports have been used, there are reasons to suspect that the mouse is going bad. It could be loose or broken joints in the mouse.
You might want to try the mouse on another machine to isolate the issue and be completely sure.
Then you can get a new Mouse for your MacBook.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
10/20/2010 1:11:39 AM • Macally iBall... • Answered on Oct 20, 2010
I have i ball 4 gb pen drive i m not able to
Look for little tiny switch somewhere on the device.
10/2/2010 3:59:15 PM • Macally iBall... • Answered on Oct 02, 2010
I want to format my usb storage device
Right click on the iBall in windows explorer and select format.
6/21/2010 10:04:36 PM • Macally iBall... • Answered on Jun 21, 2010
My pendrive is showing write protected and I am
try formatting it in any new and fresh system which is not afected by any antivirus
5/4/2010 6:50:47 AM • Macally iBall... • Answered on May 04, 2010
Hello dolfin, hi you pen drive and pc is infected by a malware type virus, scan this two with Ad aware, or Avast antivirus. thats it. Have a nice day
4/26/2010 7:30:17 AM • Macally iBall... • Answered on Apr 26, 2010
Hi friend i have a problem after coping the 1gb in
U have to check whether pendrive is in NTFS or FAT format. Change it into NTFS format by doing a quick format by enabling this check box. Right click/properties on the pendrive
12/10/2009 1:30:53 PM • Macally iBall... • Answered on Dec 10, 2009
Pen drive
Yes after 7-8 hours of continuous use
7/24/2009 11:03:36 AM • Macally iBall... • Answered on Jul 24, 2009
Webcam software is not installing. It asks for
Hi!
What ever you do DO NOT INSTALL THAT, that a program that will monitor you via your cam!
This is what i found about it and how you acn revove it:
"The file is not a Windows system file. The program has no visible window. FixCamera.exe is located in the Windows folder, but it is not a Windows core file. The program is loaded during the Windows boot process (see Registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run). FixCamera.exe is able to monitor applications. Therefore the technical security rating is 62% dangerous"
You have maleware my friend, clean up your pc
Good luck
Nic
4/2/2009 6:55:45 PM • Macally iBall... • Answered on Apr 02, 2009
This is dis-continued item for years and Macally des not have the parts for it.
1/7/2008 2:41:23 AM • Macally iBall... • Answered on Jan 07, 2008
How to turn off macally scroll lock
Click on the Apple menu in the top left corner of the screen.
Select "System Preferences" from the dropdown menu.
Click on the "Mouse" or "Trackpad" icon in the preferences, depending on the Macally device you are using.
In the "Scroll & Zoom" tab, look for the "Scroll Lock" option and uncheck it.
This should disable scroll lock on your Macally device. If the "Scroll Lock" option is not available in the system preferences, you may need to install the latest drivers for your Macally device."
2/17/2023 11:59:21 PM • Macally... • Answered on Feb 17, 2023
Macally iBall Trackball Logo
37 questions posted
Top Macally Computers & Internet Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Macally Computers & Internet
Most Popular Question
write protection in
  • Computers & Internet
