20 Most Recent Jabra Bt2045 Bluetooth Headset Questions & Answers
How long should i charge the headset and how to turn it on
The headset contains a lithium ion rechargeable battery, which should be charged before using the headset for the first time.
System requirements for battery charge using USB
Personal Computer with pre-installed with any of the following operating systems and USB port: Operating Systems (when using Windows) Windows® 7 Home Basic / Home Premium / Professional / Ultimate Windows Vista® (Service Pack 2 or later) Home Basic / Home Premium / Business / Ultimate Windows® XP (Service Pack 3 or later) Home Edition / Professional / Media Center Edition 2004 / Media Center Edition 2005 (when using Macintosh) Mac OS X (version.10.3 or later)
Charging the headset
  1. Open the cover of the micro-USB port.
Insert the tip of your fingernail in the groove, and open the cover.
  1. Connect the supplied micro-USB cable to the headset, and then connect the other end to a computer.
Make sure that you connect the plug of the micro-USB cable in the direction as shown in the illustration below. Charging starts when the headset and the computer are connected. Make sure that the indicator (red) lights up. Charging is completed in about 6 hours* and the indicator (red) goes off automatically. *Time required to charge the empty battery to its full capacity Notes
  • If the headset is not used for a long time, the indicator (red) may not light up when you connect the micro-USB cable to charge the headset. In this case, do not disconnect the micro-USB cable from the headset and wait until the indicator (red) lights up.
  • When you close the cover of the micro-USB port after charging the battery, push the catch at the edge (the round part) of the cover into the port compartment.
  1. Catch
Tips
  • If the micro-USB cable is connected to a computer while the headset is turned on, the headset will be turned off automatically.
  • To charge the headset from an AC outlet, use USB Charging AC Power Adaptor* (sold separately). For details, refer to the manuals supplied with the USB Charging AC Power Adaptor.
  • The headset cannot be turned on while charging the battery.
*Refer to the Reference Guide on the recommended adapter. Caution If the headset detects a problem while charging, the indicator (red) may turn off, although charging is not complete. Check for the following causes:
  • Ambient temperature exceeds the range of 5 °C - 35 °C (41 °F - 95 °F).
  • There is a problem with the battery.
    In this case, charge again within the above-mentioned temperature range. If the problem persists, consult your nearest Sony dealer.
Notes
  • If the headset is not used for a long time, the battery may be quickly depleted, however, after a few recharges, the battery life will improve.
  • Even if you do not intend to use the headset for a long time, charge the battery to its full capacity once every 6 months to maintain its performance.
  • If the headset is not used for a long time, it may take longer to charge the battery.
  • If the life of the built-in rechargeable battery drops to half the normal length, the battery should be replaced. Consult your nearest Sony dealer for replacement of the rechargeable battery.
  • Avoid exposure to temperature extremes, direct sunlight, moisture, sand, dust or mechanical shock. Never leave the headset in a car parked in the sun.
  • If the computer enters into hibernation mode while connected to the headset, charging will not be completed properly. Check the setting of the computer before charging. The indicator (red) will go off automatically even if the computer enters into hibernation mode. Charge the headset again in this case.
  • Use the supplied micro-USB cable only, and connect directly to a computer. Charging will not be completed properly by an indirect connection, such as via a USB hub.
Usage hours
Status Approx. usage hours Communication time (including music playback time) (up to) 30 hours Standby time (up to) 200 hours The communication time will be about 15 hours when it is charged for 2 hours. Time stated above may vary, depending on ambient temperature or conditions of use.
Checking the remaining battery
If you press the POWER button while the headset is turned on, the indicator (red) flashes. You can check the remaining battery by the number of times the indicator (red) flashes. The indicator (red) flashes immediately after the headset is turned on to indicate the remaining battery power. Indicator (red) Status 3 times Full 2 times Mid 1 time Low (needs to charge) Note
  • You cannot check the remaining battery during pairing operation.
When the battery is almost empty The indicator turns red. When the battery becomes empty, the headset sounds a beep and turns off automatically.
3/26/2016 5:07:42 AM • Jabra Bt2045... • Answered on Mar 26, 2016
Jabra talk 15 how to change the battery
See the video. Getting them open without breaking the locking tabs is the hard part. You need good Spudger skills. https://www.google.com/search?q=jabra+talk+15+battery+replacement ..
2/26/2022 5:57:06 PM • Jabra Radio... • Answered on Feb 26, 2022
Good day! How do I change my language option to English on my Jabra F600.
How do I change the voice guidance language? ' Jabra ...
https://www.jabra.com > ... > Frequently Asked Questions
Connect your Jabra device to a computer. · In the Updates section on the product support page, select the firmware language and download the file. · Open the file ...
6/12/2021 2:44:18 PM • Jabra Radio... • Answered on Jun 12, 2021
How.do.i get my jabra extreme 2 speak englidh
They are sold with the firmware and language for the country they are selling to. You have to change the firmware to your country. Easy to do with a computer.
To change the language of your device, you must upgrade the firmware with the ... How do I manually turn off/on voice guidance on my Jabra Extreme2?How do ...
Jabra Extreme 2 ' Jabra Support
www.jabra.ca > Support > Jabra Extreme 2
Get support for your Jabra Extreme 2. Find all product guides, resources and FAQs.
What is voice guidance? ' Jabra Extreme 2 ' Frequently Asked ...
www.jabra.ca > ... > Frequently Asked Questions
How do I reset my Jabra Extreme2?How do I pair my Jabra Extreme2 with my mobile device?How do I update the firmware or change the language on my Jabra ...
2/26/2021 5:00:03 PM • Jabra Radio... • Answered on Feb 26, 2021
Hi I have just brought the jabra pulse wireless headphones I have had them on charge all night the led has stayed solid green and headphones will not turn on
Read the instructions and if you are certain the headphones aren't operating out of the box as per the instructions, return them under warranty.
2/1/2020 10:40:20 PM • Jabra Radio... • Answered on Feb 01, 2020
Can I use Jabra bt2045 to listen to gps directions off phone
If your phone is connected via Bluetooth to the Jabra, I cant see why not. It would be a case of try and see otherwise contact the suppliers and ask them.
6/16/2019 7:17:28 AM • Jabra Radio... • Answered on Jun 16, 2019
I am trying to connect my jabra 9450pro headset and they cannot hear me but I can hear them. Im hooking it to a cisco IP phone 7960
See setup of your headset and check mic. Its looking mic problem.
5/13/2019 8:01:33 AM • Jabra Radio... • Answered on May 13, 2019
Jabra storm microphone not working
Mute/Unmute: Tap both the Volume up or Volume down button at the same time
4/3/2019 3:35:23 PM • Jabra Radio... • Answered on Apr 03, 2019
I don't have a charger for my Jabra earbuds,Can i use a different charger?
you can buy new ones for very cheap don't be so darn cheap
3/20/2019 11:14:43 PM • Jabra Radio... • Answered on Mar 20, 2019
Can I increase the volume on my Jabra Steel
https://www.bestbuy.com/site/questions/jabra-steel-bluetooth-headset-black/4860101/question/ae4052f2-4f6e-3f45-b0c2-ed44931c70b5 While connected to your cell phone, with bluetooth, use the cell phone volume settings to increase the volume.
2/19/2019 5:28:35 PM • Jabra Radio... • Answered on Feb 19, 2019
I have the same problem as beetank, "my BT8010 Jabra bluetooth is reading Upgrade mode SW ver.:1-33-0 in the window. Does this mean it's junk?
No, it means you are being advised to upgrade the firmware in the BT8010 to the latest version to have improved function. It does not mean your BT8010 won't work, it just won't be a versatile as if you did the upgrade. You will need the follow Jabra's instructions how to download the firmware from their internet site and install it,
1/25/2019 2:48:15 AM • Jabra Radio... • Answered on Jan 25, 2019
I have a Jabra talk 25 and want to now why I can't say answers or denied,before I bought it I ask if it does it thy said yes,it does everything I want to do but can't talk to it,can someone help
I have one too and was told that the Jabra is slowly fading out. I had to have mine replaced twice due to the same problem. go to where you bought this item and ask for a replacement for there is a warranty on these devices.
1/7/2019 6:34:57 PM • Jabra Radio... • Answered on Jan 07, 2019
My jabra E 25 does not pair with my android tablet but is ok with my android phone ?
My android tablet not pair with Jabra too, perhaps tablets have no options.
1/3/2019 7:30:52 PM • Jabra Radio... • Answered on Jan 03, 2019
Jabra freeway randomly turns off and on
In this site https://autoneed.it/bluetooth-auto/ they say Jabra Freeway is the best bluetooth device for cars. Is it true in your opinion?
12/19/2018 5:41:03 PM • Jabra Radio... • Answered on Dec 19, 2018
Jabra Bt2045 Bluetooth Headset Logo
6 questions posted
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Jabra Radio Communications
Most Popular Question
long charge headset turn
  • Radio Communications
