20 Most Recent Dell Inspiron N4010 Core I3 2.53 Ghz 14-inch Laptop 4gb Wifi Dvd Webcam R14 Questions & Answers
Hello..my laptop is dell inspiron n4010..well the problem with my laptop is that the fan doesn't work when the laptop is on..and due to excess overheating the laptop becomes extremely slow.the wor
buy a coolpad .its cheap and have 2 or 3 fans in it some have even 4 fansand it is very easy to attach with laptop through usb port just like a pendrive.buy it . coolpad will prevent ur laptop from over heating.
12/1/2012 9:10:42 PM • Dell Inspiron... • Answered on Dec 01, 2012
While using my inspiron N4010 suddenly horizontal green dotted stripes appeared at the bottom of my screen, just over the task bar..its distorting the area covered. I tried rebooting the system but t
Sorry dude, your screen have been damaged. That happens, take it in to service, they will charge you 100 US, (if no warranty) for replace it.
9/24/2012 6:05:39 PM • Dell Inspiron... • Answered on Sep 24, 2012
My dell inspiron n4010 laptop is very slow it get 30 minitue to start and hang after start while run any program
press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start. scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus if you see something running that you does not need to be running select end now then you might you might uninstall that particular program and some unnecessary programs you should also check leads from motherboard to hard drive for secure dust free connections click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes this will schedule to on restart do not have any input while chkdsk utility is in progress any might damage your computer also you might download and use this registry cleaner it is totally free to use http://download.cnet.com/ccleaner/ then defragment your hard drive adding more ram is the best way of speeding up a computer If you're not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules you should always ask for a guarantee on compatability before purchasing any ram and buy working pairs if possible you might have to many programs running at the same time putting to much strain on the CPU try uninstalling a few unnecessary programs this should speed up your computer hope this helps
8/8/2012 10:52:31 PM • Dell Inspiron... • Answered on Aug 08, 2012
2answers
How to take apart a dell mms 5650 subwoofer
funny thing about speakers is that they need an enclosure to work properly in the unit has a back and the car has a door skin or other enclosure to work in
11/5/2023 4:16:00 AM • Dell Audio... • Answered on Nov 05, 2023
Dell Jukebox Rescue Mode Have read other posts but still need help
Back it up to a computer and do a full factory reset. I just read your question tagged onto an old post. You should not be using this device to store important class notes. It is so old it could fail at any time. Notice in the link what Dell says in the manual Whenever I turn my Dell DJ on, it starts up in Rescue Mode. Your Dell DJ's firmware or operating system may be damaged. Go to support.dell.com for the .. https://www.google.com/search?q=Dell+Jukebox+Rescue+Mode ..
6/5/2023 6:33:20 PM • Dell Audio... • Answered on Jun 05, 2023
How do i open my speakers, there's no screws
Click here to follow these steps https://mybestspeakers.com/how-to-take-apart-speakers-with-no-screws/
12/15/2021 6:41:17 AM • Dell Audio... • Answered on Dec 15, 2021
2answers
I have Dell speakers, hp tower, I can't get sound out of speakers. Do I plug both the usb plug & speaker plug into tower?
If there is no separate power supply the usb plug must be used in order to provide power for the speakers, but whether the analogue cable must be plugged in or not will depend on the internal construction and specification of the speakers. I suggest you initially use the usb and if there is no sound and no on-screen instructions, plug in the analogue line. If there is a separate power supply the speakers are probably and either/or design.
12/4/2018 4:19:38 AM • Dell Audio... • Answered on Dec 04, 2018
2answers
My Dell P32E just all of a sudden started having static and dragging when playing music and also some static when not playing music. This is my lifeline! How do I fix it?
what is 'dragging'? most likely dirty contact on the plug from computer to the speakers.
10/3/2018 12:02:00 AM • Dell Audio... • Answered on Oct 03, 2018
Hello there..I've got a Dell
Windows has a troubleshooter for the audio system in most computers. Get the "fix" here: https://support.microsoft.com/en-us/help/4026994/windows-fix-sound-problems Good luck!
1/14/2018 6:06:10 AM • Dell Audio... • Answered on Jan 14, 2018
My applications last only as long as I leave my computer on. How can I make them stick?
Is there a battery back up somewhere on your computer? It could have failed. Or at least something connected with it. It could be an electronic fault. Bad capacitors etc. I assume they have ruled out a virus?
11/24/2017 8:07:05 PM • Dell Audio... • Answered on Nov 24, 2017
Background noise recording with dell
Get a wired lapel microphone and plug it into the microphone input on your Dell. The onboard mic is designed to record all ambient sounds. You want a different product to get the result you're looking for.
5/20/2017 2:35:03 AM • Dell Audio... • Answered on May 20, 2017
Altec Lansing ADA 745 speakers.
you need an amplifier
5/6/2017 10:26:40 AM • Dell Audio... • Answered on May 06, 2017
Setup Altec Lansing BX1220 speakers usb-powered...green 3.5 in back with usb next to it. I have a windows 10 free upgrade on a rebuild Dell Optiplex 755 vista desktop.
Forget the upgrade to windows 10, Dell doesn't recommend you do this as it disables some programs. I have the same computer.
9/23/2016 7:15:53 PM • Dell Audio... • Answered on Sep 23, 2016
Dell a525 speakers. One side is louder than the other. What can I do to fix this problem?
adjust the balance knob to center position
5/30/2016 5:47:12 AM • Dell Audio... • Answered on May 30, 2016
How do I find driver for my speakers. Disc not available. They stopped working after MS update.
My daughter had the same trouble with her Dell computer. The guy who was reloading Windows found the additional drivers on the Dell website. The Dell recovery disc supplied with a new machine already contain those drivers.
2/23/2016 10:30:26 PM • Dell Audio... • Answered on Feb 23, 2016
How can I fix the sound on my Windows 7 computer
Try plugging a pair of headphones or earbuds or a different pair of known-working speakers (in places of the current speakers) - if you get sound with the "replacements", then there's a problem with the "current" speakers; otherwise, the problem is the sound on the unit. Alternatively, plug the "current" speakers into a different (preferably, known-working) unit. If there's still no sound, then there's a problem with the speakers; otherwise, the problem is the sound on the original unit.
1/5/2016 1:13:42 AM • Dell Audio... • Answered on Jan 05, 2016
I have any Silex 824 Dell computer 2.1 subwoofer system the wires or cut how can I repair them properly
Joseph Nucifora, Unfortunately, Dell does not have any wiring diagrams for speakers or sub-woofers. They would replace them if they are broken and are under warranty. Thank You, Dell-Jesse L Dell Social Media and Communities
10/30/2015 5:44:22 PM • Dell Audio... • Answered on Oct 30, 2015
Dell Inspiron N4010 Core I3 2.53 Ghz 14-inch Laptop 4gb Wifi Dvd Webcam R14 Logo
9 questions posted
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Audio Players & Recorders
Most Popular Question
laptop dell inspiron n4010 problem
  • Audio Players & Recorders
