20 Most Recent
Belkin (F5D6230-3) Wireless Router Questions & Answers
I have a Belkin F5D7634-4
A virus can completely spoil your work, your computer and Leptop. It is especially recommended for all internet users to install effective antivirus software like Webroot Antivirus to eradicate the virus problem from the computer. It offers unmatched service to identify the possible threats and accordingly warn its users about the virus problem. Now if you are wondering how to install it, give us a call at 1-800-445-2810 the Webroot Antivirus Customer Service Phone number. Our certified team is ready to offer you any help remotely whenever you encounter any glitch while using Webroot Antivirus antivirus or installing the same.For more information please visit at
http://webroot.technicalhelpdesknumber.com/
6/30/2017 6:21:27 AM •
Belkin...
Answered
on Jun 30, 2017
My wireless router modem wireless
Assuming it has been running well in the past, it is likely there is some interference coming from another wireless source, most likely a cordless phone that you may have recently acquired.
Try to re-initialise the modem and see if there is any difference.
6/1/2017 9:08:48 AM •
Belkin...
Answered
on Jun 01, 2017
Can't get the wireless to work on my belkin
With the power on hold down the power button for 7 seconds and it will factory reset the router. Should have success using this, if not it means the hardware for the wireless component is faulty or broken.
4/27/2017 4:45:43 AM •
Belkin...
Answered
on Apr 27, 2017
My internet light blinks and
First reboot your router and then call your cust. service for your internet and have them trouble shoot and reset your connection.
4/27/2017 4:42:23 AM •
Belkin...
Answered
on Apr 27, 2017
Problems
WIn XP has a built in Firewall that may be enabled.
To disable this Click on Start, go to control panel and then network connections. Right click the local area connection and go to properties. Click the advanced tab and uncheck: Protect my computer and network by limiting or preventing access to this computer from the Internet.
If you do not do this it can prevent you from using the router or even accessing the router configuration screen. The reason it causes a problem is the router already has a firewall and the built in firewall can cause a problem.
8/9/2016 1:01:42 PM •
Belkin...
Answered
on Aug 09, 2016
How do I security enable my Belkin router?
Connect a computer to any one of the four LAN ports of the Belkin wireless
router. DO NOT use a wireless connection, use a cable.
Open your web browser and type the IP address of the router (by default,
the address is http://192.168.2.1.) in the address bar and press Enter.
Click Login on the top of the
page to login to the router. By default
the Password is left blank, click Submit.
Click Security under Wireless menu.
Under Security, Select 64 bit WEP (or 128 bit WEP).
Select Key 1 and enter any 10 hexadecimal digits - any combination
of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You
may also enter a pass phrase and have the router generate a key for you. Example
(0102030405060708090a0b0c)
Apply the
settings.Please write down the key – You will need it later to configure
your wireless computers with the same key.
Remember to set an admin password before you close down, other vice anyone can access you
router and change the setup and admin password.
/regards
Teis
9/9/2011 10:15:41 AM •
Belkin...
Answered
on Sep 09, 2011
My Belkin "Wireless" light keep
Try resetting the Belkin back to the default condition.
To reset the Belkin back to the default settings -
Press and hold the pinhole RESET button at the back of the router and thenpower for at least 15 secs. Then release the RESET button.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open abrowser on your laptop/computer and enter the Belkin's configuration URL.
http://192.168.2.1
The default PW = blank (just press Enter)
You can now change the default password.
You can now configure the wireless settings.
Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
4/25/2011 10:39:12 AM •
Belkin...
Answered
on Apr 25, 2011
I think I changed my belkin router to an access
Hello Geagleso,
I would recommend checking to see what your computer is using as a default gateway. Press the Windows key and the R button at the same time to open the run window and then typy in "cmd".
In the command prompt you will want to type in "ipconfig" to get the configuration of your network adapter. Your default gateway should be the router. If you still can't access the router using the default gateway IP address then you will need to reset the router using the reset button on the back of the unit near the power cable.
Thanks,
Pat
11/7/2010 2:54:37 PM •
Belkin...
Answered
on Nov 07, 2010
How can i get a
Unplug your modem then your router anywhere from 2-5 minutes, then plug in your modem then router and it should automatically reset itself and find your IP address if not call Belkin an they can help you.If you have Cox Cable you have to register w/them first they can also help w/your problem. That's what I did anyways.You would be surprised at how much they can help. Good Luck
10/20/2010 6:32:55 PM •
Belkin...
Answered
on Oct 20, 2010
Security light wont stay on belkin wireless router
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
10/20/2010 10:53:51 AM •
Belkin...
Answered
on Oct 20, 2010
How to open my NAT
PS3
And XBOX :: BELKIN
Step 1:Connect Modem - Router -
Computer (Wired)
Step 2:Open Router Setup by typing
Step
3:On the Left click firewall
Step 4:Leave the Password blank and
click submit
Step 5:Disable it and click apply changes
Step
6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP
Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the
Computer
Step 9:On the left under Firewall Click DMZ
Step
10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click
Apply Changes
Step 13:On the left Under Utilities click System
settings
Step 14:Scroll down to the bottom
Step 15:Enable
UPnP
Step 16:Click apply changes
Step 17:Test the
connection ,Check the NAT
If working then let me know
If
it is still not working
Open Router setup
At the middle
Under internet settings check the WAN IP
IF it starts with
192.168. or 172.16 Then you will have to contact your internet service
and ask them to bridge the modem
10/20/2010 10:51:30 AM •
Belkin...
Answered
on Oct 20, 2010
Belkin wireless router f5d6230-3 login error.
Because default password is not working.... Please Re-set your router in order to re configure it. Press the re set button for 1 min (tiny hole at the bottom)
Hope this info hrlps
8/24/2010 3:45:11 PM •
Belkin...
Answered
on Aug 24, 2010
