20 Most Recent Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Questions & Answers
After resetting my Belkin Wireless Pre-N router I click submit to login belkin router I get
Still not reset. Hold the reset till it cycles. A simple push only restarts it. You have to hold it in while power is on.
4/15/2020 5:42:25 PM • Belkin Wireless... • Answered on Apr 15, 2020
2answers
Connecting Apple MacBook
Try turning off encryption on your router if it is on. Many times the macs can have an issue with encryption.
10/5/2018 6:20:54 AM • Belkin Wireless... • Answered on Oct 05, 2018
3answers
Forgot the password of my belkin router
Hold the Reset Button in, (You have to use a Pen Tip) for at least 5 seconds, that should reset router back to factory defaults.
12/20/2017 9:56:25 AM • Belkin Wireless... • Answered on Dec 20, 2017
Hi. My Belkin wireless pre-n
If you cant get power to it try another power adapter with same amps if that dont work its most likely shot its most likely a diode if you can solder you can take it apart and with ohm meter figure out the one that is burnt most likely be better off purchasing one,
6/1/2017 8:57:57 AM • Belkin Wireless... • Answered on Jun 01, 2017
2answers
If i have a belkin pre-n router (# F5D8230-4)
Because the routers are pre-N they will support B-N because n isnt standard and is still a little touchy. you will be fine. but the downside, you arent getting the true N speed because your comp is running G, if you could elaborate on your computer a bit more im sure we could find an N internal card to replace the G stock. let us know
12/30/2016 12:05:04 PM • Belkin Wireless... • Answered on Dec 30, 2016
Belkin Pre-n router mac address filtering not accessible?
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers the driver might be on the disc supplied by your ISP internet service provider or the motherboard disc or you might download one if you dont have on a disk
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
hope this helps
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
8/12/2012 9:11:37 PM • Belkin Wireless... • Answered on Aug 12, 2012
How to set pin
Network Key (WEP, WPA, WPA2 Encryption key)When youclick Refresh network list, then Choose yourwireless network and then click Connect to your secured WirelessNetwork, it will asks for a Network Key before allowing you to connectinto your wireless network. This Network Key is either the WEP, orWPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphraseis an alternate way to setup the Encryption key.When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.For information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
1/17/2012 10:03:38 AM • Belkin Wireless... • Answered on Jan 17, 2012
I reset my Belkin Wireless
With a Belkin wireless router you can connect computers to the same Internet connection without having to run cables between all of them. If you don't want any stranger with a laptop that is within the range of your wireless router to be able to access your network you will first need to enable the router's security settings.
1.Power on any of the computers that are currently connected to a network through your Belkin wireless router. Click on the "Start" button and then open the Control Panel.
2. Scroll down through the Control Panel options and double-click the "Devices" icon. Right-click on the entry for your Belkin wireless router and click on "Update Driver." Wait for the latest software driver to finish downloading and then close the Devices window.
3. Open your web browser by clicking on its corresponding desktop icon. Click on the address bar at the top of the web browser's window and type in the string of numbers and dots "192.168.2.1" Press the Enter key to bring up the router's access page. Click on the "Login" button.
4. Leave the password text box blank and then click on the "Submit" button to access the settings menu. Click on the tab at the top of the screen labeled as "Wireless."
5. Find the "Security" link at the center of the page and click on it. Click on the "Security Mode" drop-down menu box and then change the security mode to whichever setting you want. Choose the "128 bit WEP" option from the drop-down menu if you want to enable security encryption on your wireless network.
6. Click on the "Generate" button at the bottom of the screen to generate the encryption key and then type in a password you want to use in the "Passphrase" text box. Leave the box empty if you want anyone within range to be able to access your wireless router. Click on the "Apply Changes" button to save the changes.
I hope you find it very helpful. Best regards.
8/17/2011 3:46:09 AM • Belkin Wireless... • Answered on Aug 17, 2011
Am not able to connect
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
3/16/2011 2:30:35 AM • Belkin Wireless... • Answered on Mar 16, 2011
I need a password for router F5D8230-4
Check your original paperwork but oftentimes the password and username default is admin, admin
2/7/2011 12:28:31 AM • Belkin Wireless... • Answered on Feb 07, 2011
Hi, I have a Pre
Try upgrading the routers firmware from the website. They have walk throughs on the website, typically you save the software from the website to your computer, log into the routers management section and update it. If that doesnt work, your router is just junk
2/5/2011 10:22:34 PM • Belkin Wireless... • Answered on Feb 05, 2011
2answers
I can't get on the internet any more with my
Welcome to Fixya
You may need to provide me some more details regarding the problem. You said you cannot go online when you disconnect the router. Is taht correct? And you were able to go online using the service modem. Could you explain to me further how you connect the computer to the router.
Your response will be highly appreciated.
Thank you for using Fixya! If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
1/10/2011 2:57:23 PM • Belkin Wireless... • Answered on Jan 10, 2011
I dont know the wep
There should be a small button that says "reset". You need to use something like a paper clip or the tip of a pencil/pen to press it. Hold this down for a few seconds (all the lights will usually flash when it's reset).
The router should now be back to factory defaults.
1/7/2011 5:16:25 PM • Belkin Wireless... • Answered on Jan 07, 2011
How to set wireless
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
12/28/2010 11:28:00 PM • Belkin Wireless... • Answered on Dec 28, 2010
The wepkey
The WEP key is assigned by the network admininstrator.If you are the one just log in in the router set up page and assign the WEP or WPA key.
. Connect the computer to one of the four LAN ports on the router.
2. Open a web browser on the computer.
3. In the address bar of the web browser, type http://192.168.2.1
4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
5. Click on Security in the left-hand column under the Wireless heading.
6. Use the drop-down menu and select "WPA/WPA2-Personal (PSK)".
7. Select either WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication; doing this will set the Encryption Technique automatically.
8. Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
a. Un checking the Obscure PSK box will allow you to see the security key that has been typed.
9. Click the "Apply Changes" button to save the settings.
Any/all wireless computers that connect to this network will be required to have this Pre-Shared Key (password).
12/18/2010 2:58:46 AM • Belkin Wireless... • Answered on Dec 18, 2010
Router was losing internet connection
Did you try a reset? Also, if you are using WEP encryption on the N router, you are only getting 54MBPS rather than 108MBPS. Use WPA. I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
12/7/2010 11:59:28 PM • Belkin Wireless... • Answered on Dec 07, 2010
I need to know which
look on the router on the bottom or at the power jack. The voltage and amperage level will be there. Then match it to the power supply that fits and has the same voltage/amp output.
11/30/2010 9:58:19 AM • Belkin Wireless... • Answered on Nov 30, 2010
I can not find or have lost my wep key code can u
If you didn't change the administrators password to access the router, plug in via ethernet cord and reset the WEP key
IP address is probably 192.168.0.1. Type that into the URL bar of the internet explorer. That will get you to the routers interface. Default password is admin or it's just blank. No user name.
11/30/2010 9:55:43 AM • Belkin Wireless... • Answered on Nov 30, 2010
I have a new modem from comcast and now my router
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
ISP Cable or Dynamic
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9: ISP DSL
Note: If your connection is DSL choose the connection type as PPOE
and set your User name and Password( ask yous ISP provider
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
========= WIRELESS SETTING UP A WIRELESS CONNECTION ====================
11/1/2010 7:58:03 AM • Belkin Wireless... • Answered on Nov 01, 2010
Hi there, I can't reset the password to my
10/27/2010 3:43:51 PM • Belkin Wireless... • Answered on Oct 27, 2010
Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
117 questions posted
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
belkin pre n router f5d8230 4
  • Computers & Internet
