20 Most Recent
Crosman Recruit Multi-Pump .177 caliber Pellet & BB Rifle air rifle Questions & Answers
Http://www.airfuns.net/faq.php#faq1
If you simple have the air go right thru each time you pump it, there is a little o-ring between barrel and the chamber, probably the one that needs replaced. Call Crosman and order by phone or go on-line.
Why my crosman recruit .177 shoots inconsistently?
I hear that the ammo has alot to do with that. .BB on a unrifled barrel gun are not as good as pellets. Lead pellets ride on the rifling in the barrel. And also your sites could be out of line. One man took the inner barrel out of the outer barrel and bent it over his knee slighty.His rifle was shooting high. On his daisy model # 880 Powerline.. But I would not go that far.A unrifled barrel is best for BB's.only.Hope I can help you out.Yours truly Joseph Alexander Bagli.
Repair manuelCrosman Recruit Multi-Pump .177 caliber...
Hi, I call crosman all the time.If it is more then a year old you can't send it back to them. But they have a great service dept. The phone number for crosman service dept is 1-800-724-7486. Ask if you can speak to cameron in customer service dept. Tell him Joe Bagli Sr from florida told you to talk to him. Hope this helps you out. Joseph.
Is the Crosman 140-70 exhaust valve cap rebuildable/can it be rerung successfully?
They are only 15 dollars to buy new. With that in mind you could attempt to rebuild it but you need at least a micrometer to measure clearances. The pictures that I am looking at show a fiber retainer and a washer seal unit. You need to see if you can get those parts individually. The fiber washer may soften if you wet it and this would make it easier to insert it because the edge of the case appears tapered. However if you do that you need to be able to dry it in its original dimension.
