20 Most Recent Tappan 18 in. MDR251RE Built-in Dishwasher Questions & Answers
Cycle starts but stop soon with in 15-20 minutes
Open the door whe the unit stops and check the water temp. you should get steam when you open the door. If not it is probably an issue with the heat circuit issue.
1/26/2014 3:25:13 PM • Tappan 18 in.... • Answered on Jan 26, 2014
2answers
What's your problem?My dish washer is not
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by leaving it unplugged for 15 minutes, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
9/18/2011 3:11:47 PM • Tappan 18 in.... • Answered on Sep 18, 2011
I have a portable Maytag
Look around the door! Locate the door gasket replace it.Check loose, crack hose, misaligned door catch as well.
9/17/2011 4:42:18 PM • Tappan 18 in.... • Answered on Sep 17, 2011
Will not clean dishes
Hi mstevemetcal,
Please follow my below Tip on how to get the best results from your Dishwasher:
DISHWASHER NOT CLEANING WELL ANYMORE...
Kind Regards d")
JEDEMEYER1
* If this solution helped you, please rate it
8/1/2011 5:41:41 PM • Tappan 18 in.... • Answered on Aug 01, 2011
I have a GE dishwasher and it seems as if the top
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
5/14/2011 11:41:43 PM • Tappan 18 in.... • Answered on May 14, 2011
Maytag quietseries 300
heatman101
5/14/2011 10:54:42 PM • Tappan 18 in.... • Answered on May 14, 2011
Forks and knifes are not clean and spoons have
heatman101
5/1/2011 12:31:08 AM • Tappan 18 in.... • Answered on May 01, 2011
I have a Kitchenaid dishwasher
heatman101
3/27/2011 6:36:27 PM • Tappan 18 in.... • Answered on Mar 27, 2011
When I put detergent in dishwasher and turn it on,
Assuming the detergent dispenser door does open, it is likely the water is not reaching the top arms. Put a cup in normal position on the top rack and see if there is any water in it at the end of the cycle.
Likely causes are blocked arms or water distributor or the wash impeller is not working in the pump. The dishwasher uses the same pump motor for wash and drain cycles. You can check this by hearing if the water is getting swashed around when the wash cycle is on.
Check the impeller and water feed as shown in this diagram.
Hope this helps.
1/19/2011 2:46:54 AM • Tappan 18 in.... • Answered on Jan 19, 2011
Top arm of Simpson EZIset
Two possibilties you could check. First make sure there are no blockages to the exit holes on the spray arm and then check that the inlet pipe to the spray arm is plugged into the back of the machine.
12/23/2010 3:47:00 AM • Tappan 18 in.... • Answered on Dec 23, 2010
DISHWASHER NOT COMPLETELY CLEANING DISHES
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...Dishwasher Spray Arms not SpinningHow to Buy Appliance Parts OnlineA bad heating element causes many problems in dishwashers...Dishwasher Problems The Heating Element not WorkingDishwasher Maintenanceheatman101
11/15/2010 2:30:46 PM • Tappan 18 in.... • Answered on Nov 15, 2010
I have a problem for a refregirator GE modle
You are right, it probably is the seal around the door...
Get a piece of paper or a CC and slide it around the seal to see if it goes hard the whole way around... if it slides very easy at points then the seal is not tight enough and should be replaced.
heatman101
10/27/2010 4:24:59 AM • Tappan 18 in.... • Answered on Oct 27, 2010
Lately my dishes in the diswasher (and silverware) come out cloud
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
9/30/2010 1:44:25 PM • Tappan 18 in.... • Answered on Sep 30, 2010
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying... Dishwasher Spray Arms not SpinningHow to Buy Appliance Parts OnlineA bad heating element causes many problems in dishwashers...Dishwasher Problems The Heating Element not WorkingDishwasher Maintenanceheatman101 578krfg
9/29/2010 3:54:39 PM • Tappan 18 in.... • Answered on Sep 29, 2010
Arms not rotating
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying... Dishwasher Spray Arms not SpinningHow to Buy Appliance Parts OnlineA bad heating element causes many problems in dishwashers...Dishwasher Problems The Heating Element not WorkingDishwasher Maintenanceheatman101 xxx
9/29/2010 3:28:29 PM • Tappan 18 in.... • Answered on Sep 29, 2010
Arms not rotating
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying... Dishwasher Spray Arms not SpinningHow to Buy Appliance Parts OnlineA bad heating element causes many problems in dishwashers...Dishwasher Problems The Heating Element not WorkingDishwasher Maintenanceheatman101 tter
9/29/2010 3:27:46 PM • Tappan 18 in.... • Answered on Sep 29, 2010
Dishwashers Logo
Popular Tags
77 questions posted
Top Tappan Dishwashers Experts
Mike Cairns
Mike Cairns
john h
Are you a Tappan Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Tappan Dishwashers
  • Tappan Dishwashers
Most Popular Question
when put detergent in dishwasher turn
  • Dishwashers
