20 Most Recent Sony D-ej011 Walkman Cd Player G-protection Cd-r/rw Grey Questions & Answers
you can find your instruction manuals
http://www.sony.co.uk/support/en/product/D-EJ011/manuals
hope that it helped
Sony D-ej011... | Answered on Feb 19, 2014
Hi Mark, check that the fiber optic cable is not damaged, has no breaks in its extension
replace and test with another cable, if the fault continues, check the audio input assignment in the Bar
I hope you can solve it
Regards Franco Dosil
Hola Mark, controla que el cable de Fibra ?ptica, no se encuentre da?ado, que no tenga quiebres en su extensi?n
reemplaza y prueba con otro cable, si la falla continua, revisa en la Barra la asignaci?n de entrada de audio
Espero que lo puedas resolver
Saludos Franco Dosil
Sony Audio... | Answered 2 days ago
Hi Darlene, the batteries of your Sony headset, are housed inside the right speaker, you will have to remove the pad, you will find the speaker cover, you must remove the four screws and carefully remove the cover and there you will see the batteries , are from Nickel Hydrogen, Sony part number:
1-756-109-11 BATTERY, NICKEL HYDROGEN
replace batteries, do not dispose of them in the trash
then do the reverse process and you will have your headphones working again
for the provision of batteries, you should look in your area for a Sony parts site
I send you the link of the MDR-F975R service manual, which are similar
I hope you can solve the battery change
Greetings Franco Dosil
Hola Darlene, las bater?as de tu auricular Sony, est?n alojadas en el interior del parlante derecho, deber?s sacar la almohadilla, encontraras la tapa del parlante, debes retirar los cuatro tornillos y sacar con mucho cuidado la tapa y ahi te va a aparecer las bater?as, son de N?quel Hidr?geno, numero de parte Sony:
reemplaza las bater?as, no las deseches en la basura
luego haz el proceso inverso y tendr?s funcionando nuevamente tus auriculares
Por la provisi?n de bater?as, deber?s buscar en tu zona alg?n sitio Sony de repuestos
Te env?o el link del manual de servicio del modelo MDR-F975R, que son similares
Espero que puedas resolver el cambio de bater?as
https://www.manualslib.com/manual/948619/Sony-Mdr-Rf975r.html
Sony Audio... | Answered on Jul 31, 2019
Hi Betty, I send you the link to download the user manual of your ZS-PS50
I hope you can resolve your concern
Hola Betty, te envio el link para que descargues el manual de usuario de tu ZS-PS50
Espero que puedas resolver tu inquietud
https://www.appliancesonline.com.au/public/manuals/Sony-ZSPS50-Boombox-CD-Player-User-Manual.pdf
https://www.manualslib.com/manual/1333767/Sony-Zs-Ps50.html https://www.sony-latin.com/es/electronics/support/boomboxes-zs-series/zs-ps50/manuals
Sony Audio... | Answered on Jul 23, 2019
Shorted speaker lead can cause damage to the output chips.
Sony Audio... | Answered on Jul 20, 2019
Sony D-ej011 Walkman Cd Player G-protection Cd-r/rw Grey Logo
1 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
free instruction manuals
  • Audio Players & Recorders
