20 Most Recent
Microsoft Wireless Notebook Optical Mouse bx300008 Questions & Answers
I have the microsoft Model
Well honestly, wireless mice are pretty cheap, but I can understand the attachment to this mouse as I gave one too.
First, try the dongle (usb stick) in another system.
If it works in another system, then the problem is with your computer, not the stick.
If not, I can't tell you how to crack the thing open without destroying it, so do so at your own riskm but you have to get the shell off the adapter and check the solder joints where the USB connector meets the circuit board and solder down .... Oh, I'd resolder all of them!
Good luck. and let me know how you make out with that!
8/26/2012 6:32:35 PM •
Microsoft...
Answered
on Aug 26, 2012
Can not connect my wireless
Most new wireless mouses or mice will connect automatically. some earlier models connect differently depending on the make and model. Usually by holding down the conect buttom on the bottom of the mouse at the same time holding down the connect buttom on the wireless device that plugs into the PC. This usually works, if not you will need to download the operator instructions or find the one that came with the wireless mouse.
Good Luck
3/13/2011 5:47:32 PM •
Microsoft...
Answered
on Mar 13, 2011
I plug in the link
try changing the batteries
if that does not work,try using the mouse near the sensor
if still doent work,hit the reset button at the bottom,remove the batteries for a couple of minutes,put it back in then use your mouse on a different surface
2/13/2011 12:42:11 PM •
Microsoft...
Answered
on Feb 13, 2011
Wireless mouse not working
Did you try
Normal
0
Turn the mouse over and find the small
rest/connect button on the bottom of the mouse and press it to
Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press
the mouse. This should be done whenever you change batteries or
glitch.
Hope this helps you. Bud
10/28/2010 6:11:02 PM •
Microsoft...
Answered
on Oct 28, 2010
HOw do I cange the
On the bottom find a battery compartment hatch. Open it and replace the battery. You may have to coordinate the signal with the receiver afterward if the cursor won't move. To do that find the tiny opening nearby and use a paperclip to push the button until it synchs (often they will blink at the receiving g end)-- you may also have to do this with the receiver if it still doesn't move the cursor.
10/12/2010 5:51:12 PM •
Microsoft...
Answered
on Oct 12, 2010
How do you get in
Should just be a cover under the mouse that clips off, you may find some youtube vids showing how to change the battery for your model
9/5/2010 4:45:23 PM •
Microsoft...
Answered
on Sep 05, 2010
I have changed the battery
press the button on the receiver device first and as it flashes click the button on the mouse it will find it then also you can un install and put disc back in should help but when the light is flashing its searching for device
8/21/2010 5:01:40 PM •
Microsoft...
Answered
on Aug 21, 2010
