20 Most Recent Belkin F1DK102P 2-port KVM Switch Questions & Answers
3answers
Don't have scroll lock on wireless keyboard/mouse combo
You can try CTRL CTRL instead of scroll-lock. it was working for me. It is not mentioned in the manual.
7/17/2014 1:12:06 AM • Belkin F1DK102P... • Answered on Jul 17, 2014
3answers
How to clean evaporator beko fridge
I've tried to remove but can't. I've now resorted to soaking up the liquid in the reservoir with kitchen roll then spraying with general household cleaner and once again mopping up with kitchen roll. You could try a weak solution of bleach or a mixture of bicarb and water instead of general purpose spray
9/30/2013 8:48:04 PM • Belkin F1DK102P... • Answered on Sep 30, 2013
Kvm switch screen resolution
Formore details please visit http://www.kvmconsolesolutions.com/
5/7/2012 11:59:51 AM • Belkin F1DK102P... • Answered on May 07, 2012
4answers
Belkin (F1DK102P) 2-port KVM Switch freezes
We have the same model and the same problem. The scroll lock combo did not work for us. You need to press Ctrl, Ctrl then up or down arrow.
The manual was a load of old Tom *** as it did not mention this.
Chard101.
5/7/2012 11:57:02 AM • Belkin F1DK102P... • Answered on May 07, 2012
0answers
Fff
Be the first to answer 8/22/2011 2:30:55 PM • Belkin F1DK102P... • Posted on Aug 22, 2011Be the first to answer
Does the F1DK102P support HPUX 10.2
It depends. The switch is an electro-mechanical device.
If the connectors on the switch match the keyboard/mouse connectors on the hardware (PC? HP?) that is running HP-UX, then you can disconnect the keyboard/mouse, connect the switch's connectors to those ports, and connect the keyboard/mouse to the switch.
3/2/2011 5:42:35 PM • Belkin F1DK102P... • Answered on Mar 02, 2011
I lost my cable for
RJ45 1 to DB25 11 RJ45 2 to DB25 3 RJ45 3 to DB25 2 RJ45 4 to DB25 18 ~ 25
12/13/2010 11:21:55 PM • Belkin F1DK102P... • Answered on Dec 13, 2010
Hi - I've jst reinstalled the switch to work with
Press the Scroll Lock key twice and then key 1 or 2 for each PC that you have attached to the cable.
Hope that helps you.
11/7/2010 3:48:32 PM • Belkin F1DK102P... • Answered on Nov 07, 2010
Computers will not switch
it has been some time since i used this particular kvm. one thing is true about all kvm's, you must boot each computer one at a time and each computer must be active on your monitor. so, turn off both computers and attach your kvm. turn on the computer that is attached to side A or 1. when the computer has reached the login screen you may boot up computer 2. check the documentation that came with your kvm, this particular belkin has a 3 stroke hot key sequence for switching. you can also find it online at the belkin site.
hope this helps,
brian
11/7/2010 3:44:08 PM • Belkin F1DK102P... • Answered on Nov 07, 2010
How do I switch between computers using old Belkin 2-port KVM?
if i remember right, hitting the scroll lock key twice, and then pressing 1 or 2, depending on which box is your xp box.
hope this helps
10/17/2010 2:01:32 AM • Belkin F1DK102P... • Answered on Oct 17, 2010
Maunal swithc does not work
Try SCROLL-LOCK, pressed twice, quickly, and then UP-ARROW or DOWN-ARROW.
8/29/2010 12:01:02 AM • Belkin F1DK102P... • Answered on Aug 29, 2010
Belkin 2-port kvm switch
mcdevito75 here, You can try to contact Belkin itself, but with-in the 2 years you had wireless, many more users of different computers, and satalites that the wireless needs have also changed.
7/13/2010 5:10:29 PM • Belkin F1DK102P... • Answered on Jul 13, 2010
What is the use of belkin 2-port kvm switch?
The use of any kvm switch regardless of how many ports is to allow you to use 1-Keyboard, 1-Video(monitor), and 1-Mouse between multiple computers.
7/7/2010 3:40:06 AM • Belkin F1DK102P... • Answered on Jul 07, 2010
How can you switch over to different computers
If your keyboard and this KVM Switch are both PS2 (from the picture I see the KVM Switch is PS2 and from the Internet searching for Scorpius -p7 trackball keyboard I see it can be either USB or PS2) the connections are straight forward.
Usually a 2 port KVM switch uses keystrokes to make the switch, they are usually "Scroll Lock" or rarely "Num Lock" -- press the key 2 times with about a second or less between presses. You may hear a BEEP from the switch indicating "it's hearing your request."
Good Luck
Jeff
6/16/2010 4:15:03 PM • Belkin F1DK102P... • Answered on Jun 16, 2010
HOW DO I SWITCH PORTS?
I've never used that switch personally, but the standard for these kinds of switches of any brand is to hit Scroll Lock twice. The manual for this model says you need to press Scroll Lock twice then the Up arrow or Down arrow. Here is the link for the product manual: http://cache-www.belkin.com/support/dl/p74242-d_f1dk102p_manual.pdf
6/6/2010 4:14:05 AM • Belkin F1DK102P... • Answered on Jun 06, 2010
No manual for Flip USB with audio
Here you are: http://cache-www.belkin.com/support/dl/p74242-d_f1dk102p_manual.pdf
If you need further assistance, just leave a comment.
4/11/2010 11:51:43 AM • Belkin F1DK102P... • Answered on Apr 11, 2010
Belkin F1DK102P 2-port KVM Switch Logo
67 questions posted
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
  • Computers & Internet
