20 Most Recent
BenQ DC2410 Digital Camera Questions & Answers
Always white picture on daylight ... why?
the lens motor for the iris isn't working so the iris is allowing too much light into your lens and the pics are too bright .... solution will involve manually turning the motor or replacing the lens altogether ,involves opening the camera .... sometimes replacing the camera may be more economical though .....
Unuseable benQ Camera
Alas these small items are designated 'Consumable' and are serviced by replacement
In other word it is time to buy another
Where can i find an firmwareupdate for benq dc c850
Please.
When an electronic device is start acting strange, a software update is the worst thing you can try to solve the problem.
Updates are only allowed if the system is working without an error.
If it is not working correct, you can't be sure it will load the update correct and you never know what happens when the update is started.
For every update there is a condition, the electronic needs to work perfect and the battery / power supply must be capable of delivering enough power during the whole update process.
I'm sure there will be no update for the Benq camera.
7/27/2014 4:27:51 PM •
BenQ Cameras
Answered
on Jul 27, 2014
How to unlock locked card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
5/13/2014 2:49:08 PM •
BenQ Cameras
Answered
on May 13, 2014
Camera hang
Always when your camera acts strange, switch it off. Wait a few seconds, till you are sure it is not accessing the memory anymore. Then remove the battery (ies). If possible first charge the battery (ies) Than replace the battery and switch on the camera. If the error comes back, you have to assume something serious is going on. In which you should contact a service centre or repair shop.
1/29/2014 12:30:58 PM •
BenQ Cameras
Answered
on Jan 29, 2014
