20 Most Recent Harman Kardon DVD-22 DVD Player Questions & Answers
2answers
Power on but nothing else
My DVD22 did exactly the same. The solution mentioned by shelompidid not apply to me since my model already had the fix factory fitted.
The other problem mentioned on page 21 of the service manual did the trick for me, although the complaint does not seem to be directly relavant:
"Complaint: Will Not Read Disc; Other Functions May Be Disabled
See h/k service bulletins HK2004-03 and HK2005-02, as the issues covered there involve similar
symptoms.
Probable Cause: EC19 and EC20 (1000μf 16v capacitors) may be defective in the power supply. This can be checked by measuring the +3.3v and +5v voltages that are associated with EC19, 20 to see if they are low (more than 0.1v low). The SPMS output voltages are marked on the PCB adjacent to the large 13 pin header. While there is only one 3.3v pin, there are several +5v pins, and care should be taken to measure the correct one(s), which are either two +5v pins approximately in the center of the header.
I could actually see on the power supply board that these two caps were damaged, although they were not completely popped. An additional cap which was damaged on my board was EC4.
When I measured the voltages the middle D +5V was reading about 4,6V. I did not expect a problem until I read the statement above on page 21 stating it should not be low by more than 0,1V. My A+14 and A-14 voltages also read about +/-17 to +/-18V.
I replaced all three caps: EC4, EC19 and EC20 with 25V caps instead of 16V caps. The voltage for D +5V now read exactly 5,01V! The A+/-14 read +/-16V (some improvement).
My unit is operating fine after replacing these 3 caps! I suspect that the damage to the caps could have been spikes on the AC suppy some stage, maybe due to lightning. Pretty amazing that only the power supply have damage and not the main pcb.
6/10/2018 9:04:24 AM • Harman Kardon... • Answered on Jun 10, 2018
0answers
0answers
Open close
Be the first to answer 10/27/2013 12:31:30 AM • Harman Kardon... • Posted on Oct 27, 2013Be the first to answer
Drawer to load dvds will not open. Needs a belt for the drawer. where can I get one
HelloLoading belts can be bought from most of the electronic spare part selling shops at your town. Keep the broken belt in hand for sample and size.
3/9/2012 9:58:58 AM • Harman Kardon... • Answered on Mar 09, 2012
Hello. I have my
hi,
Check the connections you have made between the tv and dvd player, whether you have connected the audio output of the dvd player to your tv.
if its ok the go the system setup of you dvd player and then go to the Audio setup.
In the audio setup select digital output and make it to PCM.
exit menu and test
ok
4/11/2011 7:01:39 PM • Harman Kardon... • Answered on Apr 11, 2011
Tray does not open
Hello
Its loading belt has broken. Loading and unloding are done by belt and motor drive. The belt between motor and loading gear wheel assembly have borken, that is why it doesn't opens. Replace the belt with same size. OK.
3/26/2011 3:02:02 AM • Harman Kardon... • Answered on Mar 26, 2011
Power on but nothing works
It may havenot been used for sometime.There could be a few answers to this, so i`m trying likeliest first.
I think or we have to eliminate the build up of condensation in the dvd.
Put the dvd and remote in a warm room plug in, and leave for 2-3 hrs,then fingers crossed try the dvd again.
12/3/2009 3:42:43 PM • Harman Kardon... • Answered on Dec 03, 2009
Hello, expert. i have a dvd stuck that refuses to
you probably did this already,but unplug the player,and reset,hopefully you can return it,or its under warranty and get another one.
10/31/2009 9:08:35 PM • Harman Kardon... • Answered on Oct 31, 2009
2answers
Harman Kardon AVR 300 seems to have no oompff power or kick.
Here is your remote. https://www.google.com/search?q=harman+kardon+avr+300+replacement+remote+control It sounds like components within the amp have failed. Take it to a good audio tech. It is worth fixing.
3/15/2023 2:26:02 PM • Harman Kardon... • Answered on Mar 15, 2023
How do I reset my Harman Kardon AVR151S remote control?
I don't think you can
12/27/2021 9:24:14 PM • Harman Kardon... • Answered on Dec 27, 2021
I have a Harman Kardon BDS 270 that is stuck.
Have you tested the power supply output voltages?
11/15/2021 6:38:29 PM • Harman Kardon... • Answered on Nov 15, 2021
Harman Kardon DVD-22 DVD Player Logo
16 questions posted
Top Harman Kardon Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Harman Kardon Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Harman Kardon Televison & Video
Most Popular Question
drawer load dvds will not open needs
  • Televison & Video
