20 Most Recent Yukon FF13011 Firefield 2.5-10x40 Riflescope with Red Laser Questions & Answers
fixya site doesn't do phone calls
any way if you got it in 2/14/2014 why did you not do somethinh about the problem immediately and not 4 years later
Yukon FF13011... | Answered on Mar 05, 2018
Hello, don't worry about it. It is HV to the image intensifier tube. The battery voltage goes through control circuit then to ccfl inverter (here is were dc voltage is switch on and off and switch dc voltage is step up by toroid coil that has two input and only two out puts). By impulsing the coil with two different switch dc voltage on the input this make the current lag the two different phase voltage by 90 degrees. Here is where the strange noise is coming from. The toroid coil is encased in iron case and if half of this iron case is loose, it makes case vibrate so the noise.
Now, the voltage come out of the toroid coil is switching dc (one could call it AC because that what AC voltage is, it switch between positive to negative) this voltage is about 300 to 900 switching DC voltage. This voltage will be applied to a 1/2 wave voltage multiplier (this voltage multiplier with have anywhere four four stages to 10 stages depend on what the input voltage to multiplier is.
Low the voltage out of the ccfl inverter the more stages the multiplier will have.
Now, the voltage multiplier will double the voltage per stage to need image intensifier tube voltage of 12000 to 45000 volts---DC switching or AC what ever one wants to call it. This voltage will bit you but it doesn't have a lot current associated with it, the current would be in the 10 to 15 ua (micro-amps) 1/10X6 amps.
Now, you know. GB...stewbison
Yukon Optics | Answered on Sep 24, 2011
Read the Manual:
https://www.searspartsdirect.com/manual/5xg2yzqg8w-001198
Optics | Answered 2 days ago
check and see if you see an "M" in the display....if so hold down the mode button for at least 5 seconds and change it back to "Y" yards.....try and rate.
mtg
Back or front ?
Optics | Answered on Apr 21, 2019
put a dead mouse on it
he i need a tripod to reflector telescop 525
Optics | Answered on Apr 14, 2019
We do not do appraisals.
Yukon FF13011 Firefield 2.5-10x40 Riflescope with Red Laser Logo
1 questions posted
Top Yukon Optics Experts
Marvin
Marvin
John Porter
Bill Boyd
Are you a Yukon Optic Expert? Answer questions, earn points and help others
View Most Popular
Yukon Optics
  • Yukon Optics
Most Popular Question
purchased scope from centerfire systems
  • Optics
