20 Most Recent
Mitac Mio 168 Pocket PC Questions & Answers
My Mio 168 just won't charge
The socket on the bottom of these is a common failure point. It wobbles about until the solder cracks then the device won't charge. If you're confident with a soldering iron you might be able to fix it yourself. Remove the SD card and fold the GPS antenna down. Remove the four case screws and carefully separate the back by gently prying it along the join. Watch out for the cable to the GPS antenna. Now you should be able to see the 22-pin socket. The pins are tiny. Very carefully re-solder them, and the ends of the connector where they attach to the PCB. The YouTube video seems to illustrate it pretty well.
Alternatively, there's this option which is altogether more drastic:
http://oasis.halfmoon.jp/other/mio168/mio_dc_socket.html
No gps signal on my mio digiwalker 168
Please try and reset the unit , check for fault in the settings . You can also remove the power and try a long reset and if after the boot there is no detection it is best to seek assistance specially if the unit is new as you can avail of free replacement warranty.
How do I change the
I had exactly this problem with my pocket PC Mio 168. but thank goodness, i could resolve it about 8 months ago.
you can't change the language of your pocket PC , I mean to say if you change some options or settings in your pocket PC. to resolve this problem you have to flash the Rom of your pocket PC with an other one witch contains the language you want. for example Rom with English language.
so, first you have to download the Rom and software witch it will help you to flash your actual Rom.
sorry for my english
