20 Most Recent
MPC Computers ClientPro 414 All-In-One PC Desktop Questions & Answers
How much is clientpro 414 worth?
If this machine is running XP, beware. It is no longer supported, and hackers will be looking for these machines to infect. I recommend you get a newer machine.
Good luck.
I am looking for restore software?
There may be a hidden recovery partition on your hard drive. Reboot the PC and hit F10 several times right after it reboots, but before it begins Windows. If F10 doesn't work, try other F keys. The recovery partition allows you to restore the PC to its original factory state. Just be sure you back up all your data to an external hard drive or flash memory card before you do that.
Need restore cd
You can use restore operation bro by click f8,f9 or f7 when it is on reboot mode to go back on it's main settings and configurations.
I need step by step instruction for installing memory
First check that you have bought the correct RAM.
Go to
www.Crucial.com and select 'Get the correct memory'. and check the results with what you have.
If OK probably best to remove an existing RAM chip noting carefully how it comes out and which way round.
Broadly, there is a catch at the bottom on each side, that has to be released (with a small electrical screwdriver) then you pull up at an angle of 45 deg..The slot in the centre of the RAM will only match one way round. Then replace it and try the same with your new RAM in the next empty slot.
Youcam not connecting to webcam
You need to find drivers for your webcam or its not compatible .... go to download.com and download Unknown Device Identifier it will help you find the driver and manufacture your looking for
Youcam not detecting webcam
How old is the webcam? If You are running Windows 7 a windows XP Webcam sometime will not work not work, Even if you have a setup CD.
