20 Most Recent
MPC Computers TransPort X1000 Notebook Questions & Answers
How do i switch on the wifi
This often happens due to lack of correct drivers.You should check drivers from your manufacturer,and also check the condition of your wi-fi adaptor by using the device manager.
Bypass biometrics mpc transport x1000
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :-
http://www.hirensbootcd.net/ http://67.20.82.163/
How do I update bios for mpc transport x1000
FIRST, WHY DO YOU WANT TO? Altering the BIOS is like taking a stroll in a minefield, one wrong step and........ That said, Is your computer running OK? Is there some issue you are trying to resolve? If you are asking for a "how to" , I assume you have never done it before. That's not a "pond you want to jump in", without checking how "deep the water is". I would advise you to rethink, and rethink the rethink. Have you looked on the laptop Makers website for a BIOS flash? Only use the laptop manufacturers website for BIOS updates/flash.
Transport X1000 labtop will power on but screen is blank
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad. Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display. If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
I chenge my windows from xp to 7 now my volume & internet dosent work and I haven't orginal CD how I can do?
Having had a look around, MPC don't seem to have Win7 drivers available on their web sites.This site does however list the XP drivers and the modules they're designed for.http://www.mpcdrivers.com/apps/filelist7374.htmlTheres a possible link and loads of info here in respect to your audio driverhttp://pcsupport.about.com/od/driverssupport/tp/windows-7-drivers.01.htmand here's a site which may have your wireless lan driverhttp://download.cnet.com/Actiontec-802-11a-b-Wireless-LAN-Adapter/3000-2112_4-83486.html
HOW TO REMOVE PASSWORD FROM
Dear Sir,
To remove password in your BIOS
1. Turn off your PC ang remove power cable
2. Open your PC Casing and find the CMOS battery
3. Remove CMOS Battery Located in your Motherboard
4. Most Bios Battery is CR2032 Lithium Battery
5. After removing battery Short circuit the Positive (+) and Negative (-) pin in your bios terminals using a metallic screw or any metal to connect both terminal.
6. Put back the CMOS battery to its original location.
7. Turn on your pc and press F2 or delete depending on your Motherboard BIOS key.
8. Check if you can enter the BIOS settings.
Hope this will help,
Markus
