20 Most Recent
Archos 80 G9 Tablet Questions & Answers
MY TAB IS NOT SWITCHING ON OR GETTING CHARGED
If its still under warantee you can send it in to the manufacturer to have the battery and charging system replaced. If not it has internaly 2 gel batteries that are (with some work) replaceable. They were not designed to be replaced but can be. It has 2 snap tabs on each long end that can be opened with a flat head screw driver. If it is an older model it may also have 4 screws one under each foot pad an eye glasses screw driver can remove these. Once you get it open the batteries are two identical silver rectangles that togeather take up the majority of the internal workings. They have part numbers that can be used to order new ones from radio shack or another electronics store. I recomend sending it to the manufacurer however. The not only do great work they also wartee their repairs.
Hi, my Archos 80 g9 display screen is broken, can i buy new display from you?
the display screens can be purchased but good luck finding some one to install it just google it and buy 2 because often some of them dont work from the factory ooorrr you can have archos fix it wich may be cheaper and easyer about 25% of original cost and they will test it and make sure it works before sending it back or send you a new one the screen problem is not specific to archos its specific to that type of screen they have a half life of about 5 years but may die sooner under constant use or abuse and some die as soon as they are powered having archos replace it prevents you from having to buy multiple of them to find a good one samsung also uses the same type of screen but does not use the laminating or layering proces that archos uses to increase the durability and third party screens also dont have this eather so having archos do it will also ensure you get a laminated and layered set up that will last you a bit longer than one you might purchase after market and have some one put in for you
Archos 8 tablet wont charge
the battery is coverd by warantee if warantee is expired you can replace it yourself with a little effort you will need a very very small philips and standard screwdrivers and a magnifying glass.under the kickstand is a screw and under 3 of the feet but one of them is not part of the closure it hold some of the other internals in place the 4 foot has no screw under it there are 2 very obvious screwdriver latch catches left and right of the archos logo thats what the flat screw driver is for you will need two people to do this part it has to be both at once inside is battery it actualy says batery on it repace and close up all done tricky parts : some componets are not screwed in place or held inplace by anything more that the shape of the case in the 1st and 2nd generation 80g9's this is the case with the usb port it will fall out when you open it dont panic just carefuly posititon it in the corect place again while you are closing it this is just one of many so open slowly so you can see where things become disloged from some components hold others in place with out screws if one comes out the next one tends too also
Where to buy lcd screen for archos 80 g9
not sure you want to do that you can google it, it does come up with places that sell it. problem is they dont always work you may have to buy 2 they will charge you to fix it if it is out of warantee aprox 25% of the value of the device or just shiping if still under warantee but LCD/LED is not coverd by warantee if you can convince them that the display malfunction is something other than the LCD/LED they will replace a waranteed one for shipping charges alone no questions asked but you have to convince them it is some thing other than the phisical display its self wich should not be too dificult they are pretty durable and can still display a fairly good image even when cracked in multiple places often the touch screen will also still work when cracked too not very many tablets can say that :) hope that helps
How do I remove the headset icon from my Archos tablet?
Probably you should know hor to operate Android OS. Try from the beginning get Android for Dummineshttp://www.dummies.com/how-to/consumer-electronics/Android-Phones.htmlhttp://iit.qau.edu.pk/books/Android.Application.Development.for.For.Dummies.pdf
