20 Most Recent
Samsung Un46eh5300 46 Inch 60hz Led Hdtv Questions & Answers
Samsung tv repair
I was a Samsung Tech for over 3 years, I would take it apart and look for loose connections to the panel. If that does not work, you will have to start out with smaller parts. In my opinion its the main board. Whats the model number? If you need further help, I’m available over the phone at
https://www.6ya.com/expert/jason_70466cb634a57543
5/4/2016 11:52:29 PM •
Samsung...
Answered
on May 04, 2016
Is there a reset button on television? storm last night but the set was off?
There is no such external button; to reset. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
9/14/2014 1:36:46 PM •
Samsung...
Answered
on Sep 14, 2014
UN46EH5300 adjust screen size to get whole picture and closed captions
Sounds like you have it on zoom setting. Go to the picture menu and scroll through the options. Start with 16:9 and try others if this doesn't work. If you've already tried this, you may have to go into screen setting and manually draw the picture in horizontally and vertically - but make sure you've got it on 16:9 and paused on a typical picture before you mess around with these settings.
8/29/2014 12:17:14 PM •
Samsung...
Answered
on Aug 29, 2014
Cant connect to the internet
if your internet works with other devices. Than note the ip address and use the same in TV and DNS 8.8.8.8 try it
1/11/2014 6:37:14 AM •
Samsung...
Answered
on Jan 11, 2014
How do I get my Samsung sc d 353 mini DV tape recordings on computer
To transfer the recordings from your Samsung SC D353 Mini DV tape to your computer, you'll need to follow these steps:
1. Connect the camcorder to your computer: Use a FireWire (also called IEEE 1394) cable to connect your Samsung SC D353 Mini DV camcorder to your computer. Most computers have a FireWire port, but if yours doesn't, you can purchase a FireWire adapter card.
2. Turn on the camcorder: Turn on your Samsung camcorder and set it to VCR mode.
3. Open the video capture software: On your computer, open the video capture software that came with your operating system (e.g. Windows Movie Maker, iMovie on Mac) or a third-party video capture software (e.g. Adobe Premiere Pro, Final Cut Pro) that supports Mini DV tape.
4. Start recording: In the video capture software, select the option to capture video from a DV device. Click the Record button in the software and then press Play on the camcorder to begin playing the Mini DV tape. The video should be captured and recorded onto your computer.
5. Save the video: Once the video has been captured, you can edit it if necessary and then save it to your computer in the desired format.
Note: If you do not have the original video capture software, it is recommended that you search and download compatible software before beginning the transfer process. Additionally, make sure your computer has enough storage to store the transferred files.
Samsung SC-D353 foggy lens - what can I do?
If the lens on your Samsung SC-D353 camcorder is foggy, there are a few steps you can try to clear it:
- Clean the lens using a lens cleaning solution and a soft, lint-free cloth. Be sure to gently wipe the lens in a circular motion, taking care not to scratch it.
- If the foggy appearance persists, there may be moisture inside the camcorder. You can try using a hair dryer or a can of compressed air to blow out any moisture that may be trapped inside the camcorder.
- If the foggy appearance is still present after trying these steps, there may be an issue with the lens itself. In this case, you may need to have the camcorder serviced by a professional.
I hope this helps! If you have any further questions or if you are having trouble clearing the foggy lens on your camcorder, don't hesitate to ask.
Samsung VP-D103 flashlight not turning off.
Please remove the memory card and hold the power button down for 15 seconds. If that does not turn the light off, please remove all batteries from your device. Please stay away from the power outlet where the camcorder was initially charging. Thank you.
Driver for Samsung SCD6040
Log in to Samsung web site , enter make and model on the driver site. if there is a update driver download it there .
