20 Most Recent MSI KM2M Combo-L (MS-6738-010) Motherboard Questions & Answers
The power supply is working??Are you hearing the fun??The led on the back turn on??If no then your power supply is dead
MSI KM2M Combo-L... | Answered on Jan 11, 2015
Hi
I'm sorry but I could not find anything about this motherboard / machine. However most laptops have the facility to plug in a monitor via a VGA port on the machine. If doing this works then check settings on your computer to ensure that it is not set to only display on an external monitor. If it doesn't work, try booting your computer in "safe" mode (Press F8 during boot) if you can see anything either during boot or with ext monitor. If all these fail then probably the graphics section of your motherboard has probably failed and a new motherboard will be required to solve the problem unless the graphics card is separate (unusual in a laptop of this age).
Regards
MSI KM2M Combo-L... | Answered on Jul 25, 2014
Download here at msi:
http://eu.msi.com/product/mb/KM2M-Combo-L.html#/?div=Driver&os=XP%2032
Please unzip the file before you install
Good luck
MSI KM2M Combo-L... | Answered on Nov 05, 2012
usually all drivers for Compaq and HP computer systems (portable and non-portable) can be found on the HP support website (Click here to go to it), simply go there, chose your region, than your country, enter your model number (not the series, the model number, you would usually find it on the service tag, or wherever you would find a serial number), but be sure to chose "Download drivers and software (and firmware)", and than chose your operating system. Hope this has helped.
MSI KM2M Combo-L... | Answered on Oct 12, 2012
I have a MSI motherboard KM2M Combo and I do not know whether I have to necessarily involve the outlet from the power source as the longer the ATX 20 pin power connector (CONN 1) and shorter ATX 12 V Power Connector (JPW 1), or will do, get involved If only the connector CONN 1?Thank you.
E-mail: bohuslav.bohuslav@yahoo.com
MSI KM2M Combo-L... | Answered on Nov 27, 2011
In case your op. system is windows XP you can use this official link to download the proper audio drivers (Realtec ALC series AC97). In case you use a different op. system select the proper drivers from this official link. Note that win 7 are not supported (officially) for this motherboard.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
MSI KM2M Combo-L... | Answered on Sep 11, 2011
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
Realtek AC'97 Drivers & Applications. The package includes: Driver/Application Setup Program; RtlRack for Win98/Me/2000/XP and AvRack for Win95/NT4; Realtek Sound Effect Manager. DirectX 8 is required to enable advanced features.
http://www.boxdrivers.com
using this link you will be able select your drivers
hope this helps
MSI KM2M Combo-L... | Answered on Aug 06, 2011
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps
MSI KM2M Combo-L... | Answered on Jul 21, 2011
this motherboard looks it has an eide controller you might have to check your PSU power supply units power ends that they have the sata end also you might have to check the motherboard for the IDE or SATA connection or use an adapter if it only has an IDE connector
http://www.firingsquad.com/hw/130/MSI_KM2M_Combo-L_MS-6738-010/?viewdesc=1
hope this helps
MSI KM2M Combo-L... | Answered on Apr 23, 2011
You can download the drivers from MSI WEB support site,select your model motherboard to download :- http://www.msi.com/index.php?func=downloadindex
MSI KM2M Combo-L... | Answered on Apr 14, 2011
before trying anything in Bios
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
MSI KM2M Combo-L... | Answered on Dec 16, 2010
I think the manual contains the diagrams your looking for, they are available here http://download2.msi.com/files/downloads/mnu_exe/E6741v1.1.zip
let me know if you have any trouble with the file or if you need anything else.
Thanks
Ekse
MSI KM2M Combo-L... | Answered on Oct 11, 2010
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps good luck
MSI KM2M Combo-L... | Answered on Sep 16, 2010
Click on the link below for the full motherboard installation and motherboard layout manual.
http://www.scribd.com/doc/13159820/KM2M-ComboL-MS6738-Manual
Regards.
MSI KM2M Combo-L... | Answered on Jul 23, 2010
Here is MSI's list:
http://us.msi.com/index.php?func=prodcpusupport&maincat_no=1&prod_no=527#menu
MSI KM2M Combo-L... | Answered on Apr 10, 2010
Dear friend please follow the link and down load the drivers. After open the link 1st choose your operation system then go for driver downloading.
Click the LINK
Thanks.
MSI KM2M Combo-L... | Answered on Feb 10, 2010
MSI KM2M Combo-L (MS-6738-010) Motherboard Logo
66 questions posted
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
formated laptop
  • Computers & Internet
