20 Most Recent Air-O-Swiss 7133 Humidifier Questions & Answers
6answers
Humidifier leaves film everywhere!
I talked to Kaz, a manufacturer of humidifiers, and they said this is referred to as "white dust". It's simply the minerals from your water settling on your furniture...I had to same problem so I called the manufacturer.
He said it's not dangerous but that I should use distilled water in my humidifier from now on since my water will always do that. He also stressed the importance of cleaning the unit weekly with a bleach and vinegar solution per the manufacturers specs.
3/26/2022 2:35:38 PM • Air-O-Swiss 7133... • Answered on Mar 26, 2022
White dust humidifiers harmful
I know this is an old question, however there are many of these units in use so I feel it is relevant. Actually, this white dust is harmful. If not for my Dyson purifier suddenly indicating dangerous levels of particulate in the air, I would never have pinpointed that the source of my cats developing persistent asthmatic cough, was my new humidifier. This is not benign, it's completely unhealthy. In fact their coughing persisted after removing the unit, and up until every surface was cleaned. I can only guess where else it's accumulated as it has even settled inside closed drawers. It is so fine, this dust cannot be filtered. With the amount of mineral being pumped into the air it can even inhaled into the lungs. I have never seen this much dust with any humidifier in my life. It is excessive. What is the point in buying all these filters it requires when it's not actually filtering anything? Buying distilled water is impractical and yet another expense to get a passable result from this already expensive unit. I really think think there is a deeper problem here. In my research it seems this became an issue since Boneco took over. I wish they would address this problem. Customers are out of pocket, and unknowingly exposing themselves, children, elderly, and pets to possible health problems.
5/15/2019 7:54:27 PM • Air-O-Swiss 7133... • Answered on May 15, 2019
6answers
Air-o-swiss 7135 humidifier not misting
Ours has done the same thing after only 2 weeks. From article research, it appears that this occurs to everyone after cleaning it with the EZ Cal that is recommended. From looking at our unit and figuring out how it works, it appears as though the Ultrasonic Vibration membrane has stopped working. This particular piece is responsible for vibrating the water and making water mist particles which are blown out with the air. We will be calling the manufacturer on Monday to register a complaint and request a replacement unit.
1/5/2018 5:35:07 PM • Air-O-Swiss 7133... • Answered on Jan 05, 2018
0answers
2answers
How to clean air-o-swiss humidifier?
Gererally according to the booklet in the box.
If you no longer have those instructions, simply clean out the
basin, make sure no mold, dust, hardwater or calcium is deposited.
Use a 10% bleach water solution to kill bacteria, and thats is basically it.
Just dont miss any spots, but humdifiers should be cleaned every few uses.
5/17/2014 9:04:43 AM • Air-O-Swiss 7133... • Answered on May 17, 2014
Runs for a few minutes then stops
Forget the visually appealing white mist humidifiers that leave you with a white slime to clean up. Get yourself a warm mist humidifier without the hassle, works better and no mess to clean up!
11/3/2013 2:30:09 PM • Air-O-Swiss 7133... • Answered on Nov 03, 2013
I have a clean filter, cleaned out base with white
Obviously there is something plugged up there...
Check that the dials are open and that there is no mineral buildup in the holes/vents....
The passageways that let the steam out are clogged/plugged with dirt or minerals...they will also need to be cleaned with a water/vinegar solution also...to allow the staem to escape the chamber...
heatman101
12/15/2010 7:15:22 PM • Air-O-Swiss 7133... • Answered on Dec 15, 2010
After I cleaned my air-o-swiss humidifier it no
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
9/4/2010 10:00:42 PM • Air-O-Swiss 7133... • Answered on Sep 04, 2010
I have cleaned by humidifier and changes the
First make sure the tank is properly installed rock it a bit toi see if it is secully placed.
Then Unplug it for a gfew minutes. ther replug and reset it before you start it.
2/6/2010 5:35:55 AM • Air-O-Swiss 7133... • Answered on Feb 06, 2010
Membrane on AOS 7135 needs replacement. Is it available?
Customer Questions / Repairs / Warranties / Ordering
Phone 800-336-0326 And the web address is
http://www.airoswiss.net/
some parts available, somethings need to be shipped to them
2/11/2009 5:48:57 PM • Air-O-Swiss 7133... • Answered on Feb 11, 2009
How do i clean out
EZCal Humidifier Cleaner and Descaler is what the company recomends. Also if you do not have this using equall parts of vinegar to water use the brush that came with unit. Now with this at first use if using vinegar and water it will have an odor, but the EZcal is odorless
2/11/2009 5:44:09 PM • Air-O-Swiss 7133... • Answered on Feb 11, 2009
Air-O-Swiss 7133
Okay, I just started getting this same deal with my 7133 on it's third season. I found in a blog that if you hold down the button that controls the heat while turning the mist knob on, it resets the machine. It worked. The red light went green and I turned off the heat button for cool air and the upper light still stayed green. Fingers crossed this continues to work. good luck!
2/5/2009 3:16:09 PM • Air-O-Swiss 7133... • Answered on Feb 05, 2009
Airo swiss #7133
you do not clean it should have pad in it. replace pad and you should be fine
2/4/2009 4:15:59 AM • Air-O-Swiss 7133... • Answered on Feb 04, 2009
Air o swiss 7133 doesn't send out any vapor
Interestingly enough as soon as I posted here, I was able to find the source of the problem. It appears that during cleaning the water level sensor, a bobber which normally floats as the water level rises, became stuck the to bottom of the water base - see below for the picture. I was able to use a small wooden spoon to lightly apply pressure and release the bobber so that it could float, and instantly the vapor started flowing again.
1/30/2009 4:24:18 AM • Air-O-Swiss 7133... • Answered on Jan 30, 2009
After you've cleaned it you can reset it by holding down the ON/OFF button for a few seconds.
1/25/2009 5:33:01 PM • Air-O-Swiss 7133... • Answered on Jan 25, 2009
The humidifier doesn't make enough vapor
Soak it with vinegar for several hours then use a soft nylon bristled brush to scrape off the minerlized crust and rinse. You probably need to replace the silver stick & mineralization cartridge more often.
4/10/2008 1:34:16 AM • Air-O-Swiss 7133... • Answered on Apr 10, 2008
Water dripping
still usable- just leaky
2/28/2008 5:30:20 PM • Air-O-Swiss 7133... • Answered on Feb 28, 2008
Flow of mist intermittent.
here is the manual if you need it http://www.plaston.com/uc/ats/products/ultrasonic/aos7133/index_html/manual on page 6 you can see item k - the water level sensor - i believe it is electronic not a float device (but either way the same is usually true)- usually these can fail when dirty - limescale mostly. a lot of the problems may be the result of not replacing the demineralisation cartridge often enough. descale by leaving overnight with around 40% vinegar solution full to the top, make sure the demineralisation cartridge is removed while u descale - check pages 9& 10. Hope this helps :)
3/8/2007 1:12:32 AM • Air-O-Swiss 7133... • Answered on Mar 08, 2007
Air-O-Swiss 7133 Humidifier Logo
33 questions posted
Top Air-O-Swiss Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you an Air-O-Swiss Humidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Air-O-Swiss Humidifiers
Most Popular Question
air o swiss 7135 humidifier not misting
  • Humidifiers
