20 Most Recent
MSI 915GLM-V Motherboard Questions & Answers
Msi 915gmlv drivers
You are asking for an entire operating system. No such thing as window 7 drivers. If you are asking for a motherboard driver, you can grab those from MSI's website.
What number is the pinout for 915glm-v where does
Here is the link to the location you can download the manual for that motherboard. You will ahve to select your download area but it is a small download and it will show you the exact location of all the wiring connectors.http://www.msi.com/service/download/manual-4378.htmlYou want to look at page 8 at JFP1 position. The power button connects to to JFP1 pins 6 and 8 according to the book.
CANT LOAD WINDOWS,915GLM-V KEEPS RESTARTING
Remove any add-on cards or devices to determine if they are the cause.
Reseat CPU, RAM and cables to make sure that are no bent pins and they are properly connected.
Google "memtest" download the tool, burn the CD, boot your computer using to the CD and have it run at least two full passes to make sure your RAM is good.
Plug hard drive into a working computer, download and install Acronis Drive Monitor (Free) to determine if the drive is in good health.
Swap out the power supply with a known good power supply.
The two toughest things to test are CPU and Motherboard but if you elimiate everything else one of these must be the cause. Start with replacing the cheapest one first.
I hope this helps. Good luck!
N1996
what seems to b the problem
My board is 915glm-v i
You can download the sound drivers at this page on the manufacturer's website:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=181
I have 915 glmv mother
You can download them here
(Click Here). If you are unable to download it from the website or have problem doing so, please let me know with the Operating System running on the Computer. Since drivers are compatible only with specific Operating System, it's not possible to give you the direct link.
Good luck.
Thanks for using
FixYa.
When i switch on my system simply my cpu cooling
I would start with a strip and re-build using the age old method of only the bare minimum to obtain a boot to bios first eg 1 stick of ram and if you have on-board graphics then use that.
unplug power supply and re-connect etc to ensure its not a loose power connector.
double check any and ALL board jumpers (take em off and put em back on)
disconnect EVERYTHING else
If you get a boot then its something you took out (yup all the cards came out didn't they ?)
Add one item at a time till you find the bad one.
1. floppy
2. hard drive
3. CD ROM or DVD (one at a time if you have more than one)
4. more ram
5 graphics card
6 additional cards one at a timeetc
Also double check that the motherboard is not grounding out anywhere it should not !!!
A wrongly placed board standoff can fry mobo's If you need any further assistance reply to this post
Bob
Where to Connect
I am sorry that i can't directly help you one this since there's no good large pic that i can share.. but you have an alternative.. Refer to the User Manual if you have or else download it from here
MSI 915GLM-V user manual
Good luck..
