20 Most Recent
Harman Kardon AVR 430 7.1 Channels Receiver Questions & Answers
Before buying a a used
that receiver does not have HDMI, so it will not be able to reproduce the full spectrum of surround formats from a Blu-Ray or PS3. You can still hook it up via the other inputs at reduced resolution. As for the price, I'm in America, so I can't give you a fair estimate of it's value there.
Can u hook it to a computer for sound
In general, your PC's sound card (and its controlling software) will determine what it can connect to. Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for REAL audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings. More-advanced sound cards would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards. A digital-capable receiver would accept 44.1 kHz for normal CD or DTS sources. Some diddling with the output sampling frequency might allow digital multichannel audio to be decoded by the receiver.
Harman Kardon AVR 630 8CH mode not available
According to the Harman-Kardon AVR 630 User Manual, if the 8CH mode is not available, you can try unplugging the unit from the AC wall outlet and waiting for at least three minutes. After the pause, reconnect the AC power cord and check the unit's operation. If the system still malfunctions, a system reset may clear the problem. The 8CH may not be available according to the user manual. You need to contact Harman-Kardon customer support.
Harman kardon avr 146 no front led display. but clicks on from orange light to blue. is there a fuse for display screen ? fuse at AC in is OK.
Hello, there is no fuse for the screen, there is a power supply circuit that makes it work and that if it is wrong the screen does not work
The rest of the team works well? Can you hear something?
if not, you do not have a display problem, you have a bigger problem
If you have knowledge to review it, I will attach the service manual, but go to a specialized technical service
Hola, no hay fusible para la pantalla, hay un circuito de fuente de alimentaci?n que lo hace funcionar y que si esta mal la pantalla no funciona
El resto del equipo funciona bien?, puedes escuchar algo?
si no, no tienes un problema de display, tienes un problema mayor
si tienes conocimientos como para revisarlo, te adjunto el service manual, sino dir?gete a un servicio t?cnico especializado
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Harman-Kardon-AVR-146-Service-Manual.pdf
