20 Most Recent
Mustek ScanExpress 1200 Flatbed Scanner Questions & Answers
Sterownik vista Mustek ScanExpress
From reading around, there isnt one....But i found this post
I've just installed a Mustek 1200 CU scanner on Vista.
I used the XP driver from the Mustek website.
You have to temporarily edit the registry to make the installer think you have XP
In regedit, go to
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\Cu rrent Version
Find the "product name" key. Carefully record what it says before you start. (eg paste it into a document somewhere).
Then change it to make it read: Microsoft Windows XP
Then run the Mustek XP installer, and change the registry key back to saying Vista.
The scanner works fine in Photoshop, for example, but the Vista scanning wizard doesn't detect the scanner. Don't think it uses TWAIN?
8/11/2010 9:14:47 PM •
Mustek...
Answered
on Aug 11, 2010
Cannot load driver on vista
Hi!
There is no Windows Vista compatible driver for this unit.
In the computer world this is a realy old unit (realeased in may 2001) so you should by a new one.
2/10/2009 4:27:07 PM •
Mustek...
Answered
on Feb 10, 2009
Dirver
hello try this:
http://www.mustek.com/mustek/supportdrivers.php
10/18/2008 9:01:24 PM •
Mustek...
Answered
on Oct 18, 2008
Scanner
Hi
Its very simple, All you need to get a low cost AC plug adaptor which can be found most of the DIY shops, Also you can easy cut the unfitting ground pin of the cord if you dont wish to buy the converter.
Converter looks like this
Please let me know if you need further assistance. Dont forget to rate the solution after resolve the issue.
Good Luck
7/10/2008 4:12:09 PM •
Mustek...
Answered
on Jul 10, 2008
