20 Most Recent NEC ND-2510A DVD±RW Dual Layer Burner Questions & Answers
2answers
Where can I download Win 7 driver for NEC ND-2510a
You can download NEC Driver from this site.
1/26/2015 9:50:04 AM • NEC ND-2510A... • Answered on Jan 26, 2015
My Verbatim DVD +R DL
It;s possible that you may have left the disc open or re-writable. Check this first.
The settings will be located in the software you used to burn the disc. Easiest would be to start a new burn session and read the available settings throughout the window prompts. It may also be located in advanced settings, if you don't find it this way.
6/14/2011 1:16:15 AM • NEC ND-2510A... • Answered on Jun 14, 2011
4answers
I did new window xp in my computer and the drive
If the drive shows up in Windows Explorer (My Computer) then it is being recognised by Windows XP. Put a CD or DVD in to see if works and you can see the files. If you want to burn DVDs then you need additional software to do this.
3/2/2011 7:23:28 PM • NEC ND-2510A... • Answered on Mar 02, 2011
0answers
My ND-2510A either is not burning, or not reading
Update the firmware if a newer one is available.
11/11/2009 2:01:12 AM • NEC ND-2510A... • Answered on Nov 11, 2009
Need to find the drivers ive looked everywhere
Here's the source
http://www.driversforwindows.com/nec_nd_2510a_firmware_3.26_22042.htm
Here's the driver
http://www.station-drivers.com/telechargement/nec/ND2510A_v326.exe
4/29/2009 12:42:59 AM • NEC ND-2510A... • Answered on Apr 29, 2009
NEC DVD RW help
if you are using low quality discs for recording
the dvd drive cannot burn at its full speed
the writing speed depends upon the inserted disc quality and its supporting
3/12/2009 3:53:00 PM • NEC ND-2510A... • Answered on Mar 12, 2009
Works well on CDs, DVDs won't accept file into the file system in windows burning wizard
2f8 released August 24, 2008 is the latest version
=> http://www.findmysoft.com/drivers/Nec-ND-2510A-2f8-firmware-driver.html
1/13/2009 4:07:55 PM • NEC ND-2510A... • Answered on Jan 13, 2009
Wont burn on DVD
Dunno. Do you have the latest firmware?
12/26/2008 7:42:39 AM • NEC ND-2510A... • Answered on Dec 26, 2008
Cannot write to 16x dvd discs
12/26/2008 7:41:54 AM • NEC ND-2510A... • Answered on Dec 26, 2008
Audio cd and DVD
it is mainly due to two reasons
  1. your operating system don't detect your drive
  2. its data or power cable is not properly connected
In the first case, if you are using xp, open my computer, select control panel, click add new hardware icon
  1. read and do as follows
  2. the computer automatically detect your drive
  3. if it don't detect, using manual method and add the drive
In the second case, only do if you are little technical minded
  1. open cpu cover
  2. check the data and power cables attached to the drive
  3. refix the cable some time it may in loose contact
  4. replace cable if it may contact problem
1/21/2008 6:04:29 AM • NEC ND-2510A... • Answered on Jan 21, 2008
2answers
Nec projector me423w turning off randomly
Check the Eco Mode Page 38 and Standby Mode Page 37 settings in user manual. See also page 90 troubleshooting of user manual ME403U_manual_ENG.pdf (sharp-nec-displays.com)
1/1/2024 8:22:42 PM • NEC Computers &... • Answered on Jan 01, 2024
2answers
What software or cords do I need to get/run in order to get files to transfer to/from the NEC Mobilepro 770, or even get internet?
The NEC Mobilepro 770 is a legacy device that was released in the early 2000s and uses Windows CE as its operating system. Since the device is no longer supported, it may be challenging to find software and drivers that are compatible with modern operating systems like Windows 10. Here are some steps you can take to transfer files and connect to the internet:
  1. Get the necessary cables: You'll need a USB cable to connect the Mobilepro 770 to your Windows 10 PC. The cable should have a USB Type-A connector on one end and a mini-USB connector on the other.
  2. Install ActiveSync: ActiveSync is software that allows you to synchronize files between your Mobilepro 770 and your PC. Unfortunately, ActiveSync is no longer available for download from Microsoft, but you may be able to find an archived version of the software on the internet. Install ActiveSync on your Windows 10 PC and connect your Mobilepro 770 to your PC using the USB cable. If the device is recognized, you should be able to transfer files between the two devices.
  3. Connect to the internet: The Mobilepro 770 has a built-in Ethernet port that you can use to connect to a wired network. To connect to the internet, you'll need an Ethernet cable and a wired network connection. Plug one end of the Ethernet cable into the Mobilepro 770's Ethernet port and the other end into your router or modem. You should be able to browse the internet using the Mobilepro 770's built-in web browser.
  4. Install additional software: The Mobilepro 770 comes with a basic set of software, but you may want to install additional software to make the device more useful. You can download and install software from the internet, but make sure it's compatible with Windows CE and the Mobilepro 770.
Keep in mind that the Mobilepro 770 is a legacy device, and its performance and capabilities may be limited compared to modern devices. It's also possible that some of the software and drivers you need may no longer be available or supported.
10/7/2023 6:36:01 PM • NEC Computers &... • Answered on Oct 07, 2023
How to view files from old NEC versa 4050c. hard drive op-220-62005
They don't make them like that any more! The Service Manual lists it as a standard IDE drive. Your best bet is to take it to a local computer shop. They can remove the drive and add it to a test bench set up, then transfer all the data to a pen drive as the hard drive is only 2.1 Gb. https://www.manualslib.com/manual/366990/Nec-Versa-4000.html?page=42&term=hard+drive&selected=3#manual Or use the power supply from another old computer, as the connector plugs should be the same, 12 volt and 5 volt. Or get another on eBay NEC Versa 4050c 90mhz Pentium laptop off eBay for $25 shipped. It has a 2.1gb drive, 40mb of ram. It came with a docking station. https://www.google.com/search?q=NEC+versa+4050c https://www.google.com/search?q=nec+versa+4050c+transfer+data+to+pc ..
9/9/2023 7:32:18 PM • NEC Computers &... • Answered on Sep 09, 2023
2answers
I have an NEC Multisync LCD4610-BK that I can't get sound output from. I'm trying to use it with a roku device that is plugged in via HMDI to DVI converter. How can i get sound?
DVI video cables don't carry audio. Thus you need to use an audio extractor or converter instead of just an HDMI to DVI adapter cable. Try something like this: https://www.amazon.com/J-Tech-Digital-Extractor-Converter-JTDAT5CH/dp/B00BIQER0E/ref=psdc_280341_t1_B01MQYTUAK . Then connect the HDMI to DVI cable to the HDMI out of the converter. Then the audio out to one of the audio connections on the LCD4610-BK. Note: this converter requires you to get the extra HDMI and audio cables separately. Depending on your ROKU device, you might need an HDMI (F to M) adapter to ensure that you aren't blocking other things on the front of the converter. Then set the monitor to the appropriate video and audio inputs separately. I hope this helps. Cindy Wells
6/14/2023 6:41:32 PM • NEC Computers &... • Answered on Jun 14, 2023
How do I change the time on NEC Dterm Seriesi So far I have pressed feature 4, Feature 9 then #
There is a post here: https://sundance-communications.com/forum/ubbthreads.php/ubb/showflat/Number/242170/Searchpage/2/Main/42698/Words/time/Search/true/time-change-this-weekend#Post242170SV8100 and IPKII systemsFrom any display phoneWith the phone hung up to endCheers from Atcomhttps://atcomsystems.ca
4/18/2023 8:52:30 PM • NEC Computers &... • Answered on Apr 18, 2023
Anytime I switch on my NEC laptop, it takes time to load and when it does. It turns gray with bios setup options
Hi, Please place the laptop into safe mode and run a virus scan within safe mode to ensure your computer does not have any unwanted threats that might lead to the issue that you're currently experiencing. Thank you.
7/28/2022 9:18:07 PM • NEC Computers &... • Answered on Jul 28, 2022
2answers
NEC Versa LX Screen will not come on
NEC Versa LX Screen no model told screen, a monitor is it"? the 1998 PC that? has no change at all to run zero. Pentium II (p2) relic, no modern OS run on it the coin cell battery and huge battery are toasted. hdd is bad. it has zero value now, and to fix it will be costly . the CCFL back lamps are dead. what is there to like, sure free in a garage sale. zero value. ,try moving from 1998 to 2010 to gain a future.
6/6/2022 5:46:00 PM • NEC Computers &... • Answered on Jun 06, 2022
NEC ND-2510A DVD±RW Dual Layer Burner Logo
13 questions posted
Top NEC Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ND NEC
  • ND NEC
Most Popular Question
need find drivers ive looked everywhere
  • Computers & Internet
