20 Most Recent
NEC Versa VXi PC Notebook Questions & Answers
T636400000 does it have an ethernet card built in the unit?
You are probably looking at a RJ-11, used for telephone (dial up - modem). You are trying to put a RJ-45 connector in it.
The RJ-45 should have 8 wires while the RJ-11 may have as many as 6 connectors.
Thank you for your voluntary work with this organization.
Note: If you were to plug a RJ-11 into a RJ-45 port and if it happened that you plugged the other end of the phone cord (RJ-11) into a phone jack --- and the phone were to ring ... you would be pumping 60 volts into your computer. Be very careful with these connections. You would then need butter and jelly for your toast, which is what your computer would be.
Ok - recap: Both look very similar ...
Ethernet = 8 conductors - RJ-45
Telephone = up to 6 wires (may be 2 or 4 also) - RJ-11. NOT interchangable.
So how will you connect? If the laptop is not builltin wireless, you can get a PCMIA card for the slot on the side that will allow wireless or ethernet. Get the card at your computer store. ... Or ... use the built in modem for dialup., You would of course need a dialup account somewhere.
Thanks for your question at FixYa.com
Please vote.
How to connect
Locate for a Switch with a WiFi symbol (Ususally, a Tower with emitting rays), press it (In many laptops, it will get lit when pressed), turn on your WiFi Router and wait for it to be detected, when your Laptop informs you of it, then connect it by double clicking on its icon or choose select or connect.
5/11/2014 1:32:09 PM •
NEC Versa...
Answered
on May 11, 2014
System not found
Possible hard drive fault of corrupted files.
have you tried repairing windows using recovery console ?
1/23/2014 10:40:46 AM •
NEC Versa...
Answered
on Jan 23, 2014
Power but no display
THE EXTERNAL WORKS ? IF YES MAYBE IS YOUR INVERTER DISPLAY DEFECTIVE. IF NOT YOU HAVE PROBLEM WITH YOUR CHIP GRAPHICS ON MAINBOARD AND NEED REPLACEMENT
10/21/2013 10:46:47 AM •
NEC Versa...
Answered
on Oct 21, 2013
