20 Most Recent AutoFlo 200P Humidifier Questions & Answers
The AutoFlo 2000P unit (
Tim, they're are generally not hard wired. At least, by today's standards. They're usually plugged into a receptacle. If that's not the case with yours. Open the lid and lift the float valve and tie it some way that can't lower. That will stop water from entering the humidifier tank and it should stop working. Also, look for the water line shutoff valve and turn it OFF. That way, you can be double sure it will stop running.
Hope this helped you to turn it off.
5/1/2011 12:48:10 AM • AutoFlo 200P... • Answered on May 01, 2011
I just installed a new AutoFlo 200P. I have 24V to
Like to help, but I have a similar? problem. My brand new motor turns, but gets hung up and clicks. That's why I bought a new one in the first place. Now it's hot. Tried to jiggle, make sure there is enough room for the wheel to rotate. Seems to be sufficient space. Why won't the wheel turn?
It's almost like the water weighs too much and holds it the wheel in place and the gears aren't strong enough to turn it.
1/8/2011 2:40:35 AM • AutoFlo 200P... • Answered on Jan 08, 2011
Can you tell me the recommended humidity setting?
It is fine to set the humidity level to wherever makes you comfortable Hope this helps
12/23/2009 8:08:21 PM • AutoFlo 200P... • Answered on Dec 23, 2009
0answers
0answers
On the auto 97 the float does not cut the water
If the float has no water in it.Try to flip around the small rubber stopper that pinches off the fill nozzle.
3/19/2010 10:04:32 PM • AutoFlo... • Answered on Mar 19, 2010
2answers
Can I get a replacement
Yes you can get the part replacement for your AutoFlo Humidifier, you can purchase your part from the below link -
 http://www.ontimemall.com/autoflo244Dparts.html
Post further comments if you need more help or information.......
Good Luck!!
Thanks
12/1/2009 2:33:27 AM • AutoFlo... • Answered on Dec 01, 2009
Sunbeam SCM3755C-CN Cool Mist Humidifier. I need tank assemblies please.
Question edited for clarity. Parts suppliers and a link to the maker. https://www.google.com/search?q=sunbeam+scm3755c+tank ..
1/28/2024 7:19:40 PM • Humidifiers • Answered on Jan 28, 2024
2answers
Why does my Aprilaire humidifier gurgle?
Mine was doing the same thing...first month of operation (installed toward end of heating season) = no problems with noise (bubbling, gurgling) though the duct work - started second year toward middle of season. Now its been running for a few weeks and is intolerable. I dug out owners manual and it did not address this at all. I dug out the installation manual and viola! Gurgling is caused by excess condensation in the steam hose. Sure enough the steam hose had a small area depression and did NOT have the constant downward slope necessary - installation instructions are VERY specific about needing a slope in order to allow condense to drain from the steam house. The zip-tie installation had slide down from a vertical stabilizing pipe & allowed for the hose to sag in the middle (nice install job slacker). I adjusted it and the SOUND IS GONE. Hope this helps someone else.
1/27/2024 8:11:06 PM • Humidifiers • Answered on Jan 27, 2024
I can't get my humidifier to get the humidity to get over 17% and the dial is set at 30% it goes to 20% and flashes
Without brand and model, my advice is definitely a shot in the dark. Only your manual or your manufacturer's site can inform you of what the flashing means. Here are some tips that might help you increase the humidity in your room: Check the humidifier's water level: Make sure that the humidifier has enough water to function properly. If the water level is low, the humidifier may not be able to produce enough moisture to increase the humidity in the room. Clean the humidifier: Over time, mineral deposits and bacteria can build up in the humidifier, which can affect its performance. Clean the humidifier regularly according to the manufacturer's instructions. Place the humidifier in the right location: Place the humidifier in a central location in the room, away from walls and other obstructions. This will help the humidifier distribute moisture evenly throughout the room. Use a humidistat: A humidistat is a device that measures the humidity in the room and automatically adjusts the humidifier's output to maintain a desired humidity level. If your humidifier does not have a built-in humidistat, you can purchase a separate one and use it to control the humidity level in the room.
1/19/2024 4:21:25 AM • Humidifiers • Answered on Jan 19, 2024
Elektra humidifier has a flashing water warning sign
Is this a mist generator with an ultrasonic element, popular for "health?" These have a wick and water is not going trough the dry wick by itself. One should make all of the wick wet, from bottom to top. After that the water keeps being taken up to the element until the device is stored and the wick dries out again. Another thought is that these ultrasonic elements are very similar to a buzzer, like in toys. Two round sheets of metal with plastic in between. This is not like having long lifetime. For expensive mist makers you could perhaps order a new element but I do not have high hopes. Being so vulnerable the humidifiers are shipped containing no water. It is important to rest the top of the wick in water also. Just making the wick wet close to the element does not help or gives bad results.
11/19/2023 4:04:59 AM • Humidifiers • Answered on Nov 19, 2023
Do you carry parts for this humidifier water tank?
this forum does not sell parts. call manufacturer of goggle you make and model number +parts.
11/12/2023 11:42:49 PM • Humidifiers • Answered on Nov 12, 2023
AirCare.condole evaporative humidifier, won't run, shows EE code.
If it has a humidistat in the power cord it may have gotten wet when refilling. Blow the water out, or remove the screw to open the small casing and dry it out. If it was wet, the unit should start running normally.
11/9/2023 3:30:46 PM • Humidifiers • Answered on Nov 09, 2023
2answers
HumiHumidifier was running. because water level was level I filled as usual. now it doesn't run.that's the problem.Pleas help
There could be several reasons why a humidifier stops running after refilling it with water. One of the most common reasons is that the humidifier's float switch is stuck in the "low water" position, which prevents the humidifier from turning on even after refilling it with water . Another reason could be that the humidifier's water level sensor is malfunctioning, which causes the humidifier to stop running even when there is enough water in the tank/ If you have a whole-house humidifier, it could be that the humidistat is set too low, which causes the humidifier to turn off even when there is enough water in the tank 1. Alternatively, if you have a portable humidifier, it could be that the unit's motor has burned out or that its fan has stopped working . To troubleshoot this issue, you can try cleaning the float switch or replacing the water level sensor if they are damaged. If you have a whole-house humidifier, you can try adjusting the humidistat to a higher setting. If you have a portable humidifier, you can try replacing its motor or fan
10/15/2023 1:13:24 AM • Humidifiers • Answered on Oct 15, 2023
2answers
The humidifier was running.Because water lecel was low. I filled it as usual. Now it doesn't run. Why
10/15/2023 1:12:26 AM • Humidifiers • Answered on Oct 15, 2023
3answers
What are the benefits of buying a Humidifier?
There are many health benefits of using humidifier at home, it increase the indoor humidity levels in winter. Which make air dry and moisture is essential for preventing nose bleeds and relieving dry cold, allergy and asthma symptoms etc. It also good for children skin and pets, you should use cool mist humidifiers for safe environment for your children. GroomNStyle Top 5 Best Saucepan and Pot reviews 2015
8/9/2023 7:09:56 AM • Humidifiers • Answered on Aug 09, 2023
Mainstay Ultrasonic Humidifier model number PJ1011. I need a manual for it please?
Yes you are correct, there is no manual for it, just pictures and sales information. https://www.google.com/search?q=Mainstays+Ultrasonic+Humidifier+PJ1011+manual ..
7/2/2023 11:02:05 PM • Humidifiers • Answered on Jul 02, 2023
AutoFlo 200P Humidifier Logo
6 questions posted
Top AutoFlo Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you an AutoFlo Humidifier Expert? Answer questions, earn points and help others
View Most Popular
AutoFlo Humidifiers
  • AutoFlo Humidifiers
Most Popular Question
autoflo 2000p unit
  • Humidifiers
