20 Most Recent
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm and EF 75-300mm Lenses Questions & Answers
Cannot see an image in the viewfinder of my
Hi there:Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it.Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.Thank you for using FixYa, have a nice day.
My cannon rebel eos DS6041 displays error 99 when
'Error 99' indicates some problem with
the AF contacts. This is a common error in Canon lenses. It could
indicate a very simple problem like dirty contacts or a much serious
one like the breakage of USM cable.
As a first step, you can try
cleaning the lens and body contacts (the metal contacts between the
lens and body) using a pencil eraser. Be careful to hold the body
facing down so that no dust falls inside. After cleaning both the
lens and the body contacts, re-attach the lens and try shooting. If
the AF does not work still, you need to take the lens to an
authorized service center.
My Canon EOS 300D has
Hi
I think your unit has memory card receptance unit bad.( the CF card inserting area pins---bent and shorting), or some of loosen screw moving around and shorting. Mostly it is the pin problem. Your local repair shop would charge around $50 to 195 depend on what they really want to charge.
If you are going to repair shop, ask them check your CF card female socket condition.)
Thanks and best regard!
Hello! I am getting an Error 02 on my Canon 300D
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Short battery life
After about a year of use/charging and recharging the batteries typically need replaced with OEM battery. some of the knock off brands dont work well, so buy canon from a retailer like BH. If it is a new battery, set the auto shut off to one minute and the LCD review to 2 seconds to preserve power.
Cannon EOS Rebel XS shows busy display stopped working
Just got a brand new camera. Played around with it a few nights to learn all the parts and buttons. Went to a concert tonite. While waiting for the show I took many test shots to see how the camera would work under these contiditions. Used a 75 to 300 Cannon lens. I had just got the settings about right when the show started. All of a sudden the display went dark and "busy" flashed in the view finder. But it would not take any more pictures. Taking the battery out and removing the sd card did not help. The auto focus and flash still worked but nothing else.
This camera is going back to the store if I can't get some help. PLEASE............. vj
I have the same problem.
I can help you fix the
BUSY Error or
Error 99 of your Canon EOS 1000D.
Installation of this Canon EOS 1000D firmware version 1.06 update will solve these problems:
- Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
- The message, "Err 99 Shooting is not
possible. Turn the power switch to<OFF> and <ON> again or
re-install the battery", appears on the camera's LCD monitor, and after
the above operation is carried out,the LCD monitor displays in a
language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these
Fixya Tips :
- Follow this link to download a pdf version of the firmware installation instruction guide.
- Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
- Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
- Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Err 99 followed by the "Busy" issue in the viewfinder
BUSY Error or
Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
Fixya Tips :
I hope that helps.
I have a cannon Rebel EOS and when I take pictures
That's normal. The Digital Rebel works as SLRs have worked for half a century, using the viewfinder to frame and compose your pictures. Only the more recent dSLRs have the Live View capability to allow you to use the display to frame and compose your pictures.
