20 Most Recent LifeView Fly Video 3000 (701013821560) Video Capture Questions & Answers
try this
http://www.lifeview.com.tw/html/products/internal_tv/flytv_prime30.htm
LifeView Fly... | Answered on Nov 15, 2012
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers hope this helps dont forget to vote
LifeView Fly... | Answered on Mar 14, 2011
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
LifeView Fly... | Answered on Jan 13, 2011
i need the software for Nescito el key del cd life view Fly video 3000
LifeView Fly... | Answered on Nov 21, 2010
Animated Technoligies tw is "lifeview" web
Flyvideo 3000 eq to Flytv prime 30 card just alternative name
Re XP all drivers on web
but not sure if covers XP64 as no use
Note Lifeview Flytv prime30 the best TV + Video card ever used ( i now have 4 as my hobby is capture and dvd generation) using several comps
LifeView Fly... | Answered on Mar 28, 2009
can u hear sound ,,and if not you need to download the sound drivers to hear sound and to record sound and you can download it from this website
sound drivers ---> http://www.softwarepatch.com/utilities/ac97.html and http://www.softwarepatch.com/utilities/ac97.html
LifeView Fly... | Answered on Jan 17, 2009
Hi There, Try This:
Right Click On My Computer (Or Computer For Vista)
Open Device Manager, click on the Plus for Universal Serial Bus Controllers and look for Unknown Device. Right Click on that and click uninstall. After you have done that, unplug it then reconnect it.
That should work.
Cheers
LifeView Fly... | Answered on Dec 24, 2008
yeah there is...but its NOT stable....
LifeView Fly... | Answered on Nov 02, 2008
click on settings (the wrench), then the "record settings" tab and then you can set where it puts them. Then for the "timeshift recordings" go to the "Misc Page" tab and do the same.
LifeView Fly... | Answered on Aug 09, 2008
download the factory defaults and reload them into it then upload your new fix back in to it
LifeView... | Answered on Apr 16, 2009
You must have a remote which will allow you to program in the Direct TV box to it. If you want to program your TV to your Direct TV remote, go here for more information: https://www.cabletv.com/blog/how-to-program-directv-remote/
Televison &... | Answered 3 hours ago
Hi Iva, try changing the entry with the remote control, look for the SOURCE key and press it until you see what you want to see
If you don't have the remote control, that SOURCE key or function should be on the TV
I hope you can solve the problem
Regards Franco Dosil
Hola Iva, prueba cambiar de entrada con el control remoto, busca la tecla SOURCE y ve presion?ndola hasta que aparezca lo que quieres ver
Si no tienes el control remoto, esa tecla o funci?n de SOURCE, deber?a estar en el televisor
Espero puedas resolver el problema
Saludos Franco Dosil
Televison &... | Answered 5 hours ago
Hi Joannie, for what you describe the problem is in the backlight of the LCD panel
You have one or more LEDs burned and that's why it doesn't work
The correct solution is to change all of the LEDs, these are mounted on aluminum strips, if the three strips are replaced
I hope you can solve the problem, but consult a specialized technical service
Hola Joannie, por lo que describes el problema esta en la iluminaci?n trasera del panel LCD
Tienes uno o mas LED quemados y por eso no funciona
La soluci?n correcta, es cambiar la totalidad de los LED, estos vienen montados en tiras de aluminio, en si se reemplazan las tres tiras
Espero puedas solucionar el problema, sino consulta un servicio t?cnico especializado
LifeView Fly Video 3000 (701013821560) Video Capture Logo
22 questions posted
Top LifeView Televison & Video Experts
Ekse
Are you a LifeView Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • LifeView Televison & Video
Most Popular Question
flytv prime 30
  • Televison & Video
