20 Most Recent Canon PowerShot A40 Digital Camera Questions & Answers
Two ways.
Connecting to the computer via the lead, you should open Windows File Explorer and you will see the storage in the camera as a removable storage
or
you go to the Canon website and get all the software including the download software and add-ons. The Win 7 software should be good on Win 10 and includes ZoomBrowser and PhotoStitch.
https://www.usa.canon.com/internet/portal/us/home/support/details/cameras/support-point-and-shoot/powershot-a-series/powershot-a40
Canon PowerShot... | Answered on Sep 03, 2019
thats also known as a powershot a40 - heres the support site for that camera http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=221&modelid=8288 if you goto the drivers and download tab - here you will find a manual - for zoom browser and the camera You should be able to connect the camera to your computer with a supplied USB cable - and then the zoombrowser software should detect your camera connected and offer to transfer images In the manual on Page 126/128 explains how to connect camera to PC Also explains in the manual how to transfer the images. If your PC has a memory card reader you can transfer that way - also explained in the manual
Canon PowerShot... | Answered on Jan 25, 2016
From the REC menu, select Setup and then select Format.
Full instructions are in the "Formatting a CF Card" section of the manual (page 98 in my copy). If you need a manual, you can download one at
http://gdlp01.c-wss.com/gds/7/0900001157/01/PSA40A30CUG-EN.pdf
Canon PowerShot... | Answered on Aug 29, 2011
images are stored on standard Type I CompactFlash cards. Consider the included 8 MB card a starter capacity, since its 12-picture limit means you'll need to return to your computer often to transfer images and free up the card for more pictures. A 128 MB card is a great size for this camera, storing around 200 images. To transfer images to your computer, simply attach the included USB cable between your PC and your camera. Your computer should automatically recognize your camera and let you move the pictures to your hard drive. Simply click on my computer click on new drive shown in this folder, select all the pictures, copy them and past to your desired location,
you can also copy picture by using card reader, put the SD card in card reader and follow the same procedure
Good luck, do rate the solution if helped
Canon PowerShot... | Answered on Jul 29, 2011
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or Windows Photo Gallery or any other photo cataloging program.
Canon PowerShot... | Answered on Jun 26, 2011
you can download your camera driver here:
http://www.driverskit.com/freedownload/Camera/Canon/PowerShot_A40_WIA_4_1_0/18163.html
if this was helpful please give it a thumbs up to help others
Canon PowerShot... | Answered on May 18, 2011
Consider NOT using a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Canon PowerShot... | Answered on May 05, 2011
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Canon PowerShot... | Answered on Apr 25, 2011
You can download Canon software from
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a40#DriversAndSoftware
You might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
Canon PowerShot... | Answered on Apr 02, 2011
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Canon PowerShot... | Answered on Apr 01, 2011
Canon PowerShot... | Answered on Jan 20, 2011
Canon PowerShot A40 Digital Camera Logo
77 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
load pictures from powershot a40
  • Cameras
