20 Most Recent Canon PowerShot SD10 / IXUS I Digital Camera Questions & Answers
3answers
Image blacked out on LCD and can not see image in view finder
Try connecting it to a computer and then turning on the camera. For some reason that fixed it for mine.
8/29/2017 5:59:25 PM • Canon PowerShot... • Answered on Aug 29, 2017
Cigarette lighter does not work for charging in a 2009 Jetta
It won't charge in any other car, either. The SD10 is a camera, not a battery charger. To charge the battery, remove the battery from the camera, put it into the supplied battery charger, and plug the battery charger into a power source. See page 20 of this manual.
12/26/2012 10:22:28 PM • Canon PowerShot... • Answered on Dec 26, 2012
Nu am cd de
http://driverscollection.com/?V=Canon&S=66sau http://www.nodevice.com/driver/Digital_IXUS/get36970.html that should work.. daca nu search pe google ca mai sunt o gramada de variante;)
10/25/2011 11:32:26 PM • Canon PowerShot... • Answered on Oct 25, 2011
2answers
Try this, it may or may not work. Insert the Video cable plug in and out of its slot a few times. The cable when inserted turns the screen off. But sometimes corrosion can build up on the internal plug switch, also causing the screen to turn off. Inserting and removing the cable a few times can sometimes knowck off this corrosion.
7/25/2011 11:43:48 PM • Canon PowerShot... • Answered on Jul 25, 2011
I have a ASUS EeePC
If you're talking about downloading pictures, you can do what the pros do....use a card reader.typrice_187.jpg
5/16/2011 7:04:45 PM • Canon PowerShot... • Answered on May 16, 2011
Mau mencari baterai canon PC1060 i
i need to find a replacement LCD TFT Screen for Canon IXUS i SD10 digital camera Model number PC 1060
5/3/2011 5:53:44 PM • Canon PowerShot... • Answered on May 03, 2011
My model is SD 10.
switch to a sd card of less than 2gb as your camera's internal image processor power is being used in running or reading the huge 2gb sd card ...and that is the reason the image izz getting white ...try for 1gb or less ..
1/31/2011 3:24:01 PM • Canon PowerShot... • Answered on Jan 31, 2011
I would like you to
Try the site: http://www.retrevo.com/support/Canon-SD10-Digital-Cameras-manual/id/200ag109/t/2/
1/5/2011 7:02:55 AM • Canon PowerShot... • Answered on Jan 05, 2011
I have a canon pc1060
MANQUE BATTERIE
12/22/2010 11:59:40 AM • Canon PowerShot... • Answered on Dec 22, 2010
Lines on screen when i
This is due to an internal sensor that is bad.
Try the following before sending for repair:
- Use fully charged battery.
- Carefully clean the points of contact between the battery and the camera ( carefully!)
If this doesn't work contact this company for repair. They are very reliable and will make sure your camera is 100% again. Costs 1/3 of the price of a new one to fix!
http://www.teleplancamerarepair.com/Canon_Powershot_SD10
10/4/2010 8:42:32 PM • Canon PowerShot... • Answered on Oct 04, 2010
Canon E25 camera error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
7/10/2010 8:29:36 PM • Canon PowerShot... • Answered on Jul 10, 2010
Can i use my usb cable to charge my canon sd10
No. The camera does not incorporate any charging circuitry, that's why they supply a separate charger. The USB is used to communicate with a computer, not to supply power.
6/29/2010 5:09:30 PM • Canon PowerShot... • Answered on Jun 29, 2010
Downloading to Kodak EasyShare 5.2
Yes you can, the kodak Easyhare software is compatible w/ other cameras
12/29/2009 12:07:37 AM • Canon PowerShot... • Answered on Dec 29, 2009
Digital ixus i power shot sd10
Could be deffective CCD chip. CHeck with Canon service, they repair it for free
12/7/2009 9:59:56 PM • Canon PowerShot... • Answered on Dec 07, 2009
Canon PowerShot SD10 / IXUS I Digital Camera Logo
53 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
canon pc1060
  • Cameras
