EARTHS TRANSFORMATION INTO THE 5TH DIMENSION I WOULD LIKE TO SHARE WITH ALL THE OCCUPANTS OF MOTHER EARTH THE
REASONING BEHIND THE "DOUBLE SHADOW". MOTHER EARTH HAS BEGUN A
SERIES OF EVOLUTIONARY TRANSFORMATIONS, ONE OF WHICH IS
AFFECTING THE NORTH POLE, OR MAGNETIC POLE, THE REASON FOR THE
NOW "QUADRUPLE SHADOWS" IS THE EARTHS ROTATION SPEED. EARTH IS
PREPARING FOR A DIMENSIONAL SHIFT, FROM A 3D TO 5D. HENCE THE
REASON FOR BINOCULARS TO SHOW DOUBLE IMAGES, THEY AREN'T BROKEN,
THE "FUZZ" OR "FREQUENCY SNOW" ALL AROUND, VISIBLE TO CAMERAS,
RECORDERS ETC. THE SHADOW ENHANCEMENT AND VISUAL INTAKE OF SUCH,
ALSO SEEMS THAT BLURRY IS EVERYWHERE, IT IS NOT YOUR VISION, IT
IS THE MAGNETIC ENERGY , NOTHING SEEMS TO WANT TO FOCUS, SEEMS
AS THOUGH THERE IS A MIST OR FUZZY FILM EVERYWHERE. tHESE ARE
THE PHYSICAL SIGNS OF THE EARTHS NATURAL AND NECESSARY CHANGE.
NOW IS THE TIME FOR ALL TO FILL THE EARTH WITH LOVE, LIGHT
HAPPINESS AND INNER PEACE. I PUSH INTO ALL OF YOU , HAPPINESS,
JOY AND LOVE. lIGHT SHALL BEAM THROUGH AND AROUND ALL OF YOU
AND YOURS. POSITIVITY AND AWAKENING TO ALL WITH LOVE.
If you have windows - use windows movie maker. After you import the clip - go to toos>effects. Here you have the option to rotate it 90 or 270 degrees (depending on how you took the video). when you finish - plublish the movie. Now it should be rotated
You can download a manual and order a USB cable from the manufacturer's web site at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=221&modelid=8775
Before you buy another USB cable, consider this: The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
There are also plenty of photo catalog software packages out there, some free, some not, that can transfer and catalog your pictures so you can quickly find pictures from Susie's birthday party, for example. Just do a google search for "photo catalog software".
That control board is shot or perhaps the connection to the main board is at fault. Shame but repairing those cameras is very labor intensive and hard to work on. And the parts are not cheap either. I am crazy about my SX 50 but if anything like that happened to me I would just go to ebay and get another one inexpensively. Many repairs on cameras are simply not cost effective.
Use your camera menu button to access various settings options. Use that to restore your camera to default settings/ factory settings. The default settings will me a good pre-configured basic setting in which your camera can perform well if you are not sure about the custom settings.
Are you sure the battery still has enough power (even after charging) to let the lens motor do its job?
Are you sure there is no mechanical problem, you can see on the outside? Did anyone stop the lens, while it was coming out? Did anyone drop the camera, while the lens was out?
There cam be a lot of reasons, why a lens won't retract. Could be some force was used, also could be something just went wrong inside the camera. Like a gear that broke inside, or the motor stopped working. A contact failed and perhaps lots of other things.
If you already took out the battery, and reinserted it, and nothing changed, The only thing you than can do is after getting the battery out, is recharge the battery and then put it in.
If you have a spare battery, or you know anyone who has the same battery, try that battery. If nothing indicates a mechanical failure, and nothing helps, just contact the Canon Service Centre closest to you. First ask what a possible repair will cost. hen decide if you would like it repaired or you want a new camera.
New camera's are much better and cheaper than cameras last year.
