20 Most Recent Canon EOS-1Ds Mark II Digital Camera Questions & Answers
2answers
The diopter lens inside the
This will require disassembling the camera to remove the top cover and viewfinder mechanism to re-seat the diopter lens and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be done by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have it repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
5/18/2019 2:39:47 AM • Canon EOS-1Ds... • Answered on May 18, 2019
Hi there, getting I'm Er 2
Error 02 indicates a problem accessing the memory card. Try formatting the card and see if that cures the problem, if not try a different card. If neither helps you probably will need to send it to Canon for service.
5/8/2011 11:11:59 PM • Canon EOS-1Ds... • Answered on May 08, 2011
2answers
Got error 99 on canon 1D MARK II. When I push
Error 99 is a generic error code that usually, but not always, means some kind of lens error. You will need to go to the support section of the Canon website to get specific instructions for your model camera. After 21/2 years, you might try cleaning the contacts on the camera body and the lens where they meet using a cotton swab lightly dampened with rubbing alcohol.
9/27/2010 6:02:31 AM • Canon EOS-1Ds... • Answered on Sep 27, 2010
Users manual for canon eos-1 d mark 2n
http://www.usa.canon.com/cusa/support/consumer/eos_slr_camera_systems/eos_digital_slr_cameras/eos_1ds_mark_ii#BrochuresAndManuals
8/25/2010 5:26:09 PM • Canon EOS-1Ds... • Answered on Aug 25, 2010
3answers
I need an operating manual for my Canon EOS 1D MK
Hey,
heres a instruction manual http://www.cleaningdigitalcameras.com/pdf/EOS1DsMII-IM-EN.pdf
Let me know if you need anything else. Thanks,  Ekse
8/25/2010 1:32:46 AM • Canon EOS-1Ds... • Answered on Aug 25, 2010
I have a white streak
this is a classic ccd problem.. you have a internal ccd falt.. if the camera have garantie ship it to the seller. if you dont have garantie..this is a problem that can solve a professionist. why change the ccd is not so dificult if you have a specific knowledge. if you dont have knowledge you can make this only if you have a expert that give you diect istruction..and it is not so easy. if you was here in italy i can help you but we are to far. prove to contact this mail and explain the problem and ask how mutch is the cost to fix it
[email protected]
8/10/2010 7:14:11 PM • Canon EOS-1Ds... • Answered on Aug 10, 2010
Light streak shows up on display screen after the after the shot.
I am experiencing the same problem. Upon zooming in the streak gets bigger as well. It does NOT remain static. I need to thry to upload the pictures and see if the streak is there as well. I am trying a complete restart. (IE take lens off and take the battery out for 30 plus minutes
7/17/2010 8:39:26 PM • Canon EOS-1Ds... • Answered on Jul 17, 2010
2answers
White band suddenly began appearing on every image.
HI I AM SAGHA A CAMERA REPAIRER FROM MUMBAI, I THINK THE SYMPTOMS YOU HAVE OBSERVED ARE THE SYMBOL OF MINUTENESS & PERFECTION OF YOUR WORK.ANY WAY IT IS A COMMON PROBLEM OF SHUTTER BLADES OF 1DM2,IDSM2,IN WHICH ONE LEAF OF THE 2ND SHUTTER BLADE GETS DAMAGED WHICH GIVES WHITE BAND OF BRIGHTER LIGHT FROM LEFT TO RIGHT(NOT OF LINEAR SIZE). I THINK IT WILL BE LITTLE COSTLIER TO GET THE WHOLE SHUTTER BLADES REPLACED.IF U WOULD HAVE BEEN IN INDIA I WOULD HAVE GIVEN U SOME CHEAPER OPTION(LIKE REPLACING ONLY DEFECTIVE BLADE ONLY)WHICH NO SERVICE CENTRE WILL GIVE YOU.ANYWAY GET IT REPLACED FROM REPUTED EXPERIENCED REPAIRER & CHECK SLOWEST & FASTEST SPEEDS AFTER REPAIRING THE CAMERA.REPLY ME WITHOUT FAIL THANK YOU & ALL THE BEST.
7/17/2010 2:55:44 AM • Canon EOS-1Ds... • Answered on Jul 17, 2010
tip
Canon EOS 1Ds Mark II digital camera Manual(PDF)
Hello
Here is a great tip explaining where you will be able to find and download an updated PDF version of this manual. This site will also provide you with a huge database of other product user manuals. Click HERE to find out exactly how to download the manual.
At this link you will also be able to read reviews on this product, compare prices, and get a general overview. There will also be a full spec sheet on this product.
Click HERE to navigate to Retrevo, where you will be able to download the manual.
Also feel free to visit Canon's official website.
I really hope this can be of help. Please rate accordingly.
Kind regards
Andrea
I occasionally get an err 99 when shooting a
You should be using a class 6 or 10 card with a fast write speed.
2/23/2010 2:24:53 PM • Canon EOS-1Ds... • Answered on Feb 23, 2010
Need wire diagram for Canon 1d mark 11
if it's any help, I've got the top off my 1D Mk II and wiring as per photo link:
http://joeseph101.servebbs.com/Odd_files/3E7C3645-700.jpg
cheers.
1/10/2010 8:29:51 AM • Canon EOS-1Ds... • Answered on Jan 10, 2010
Diagonal black line across the bottom right corner
Most likely the shutter blind is sticking and not getting out the way when you take a picture. It will need a service.
11/29/2009 10:38:28 PM • Canon EOS-1Ds... • Answered on Nov 29, 2009
My computer will not recognize my camera
Use a card reader instead.
11/13/2009 10:42:23 PM • Canon EOS-1Ds... • Answered on Nov 13, 2009
Shutter freezes
heres the answer to the dreaded 99 error
acquire a penscil withy an eraser on the end
remove lens and hold it mount down but at a height that you can rub the pins so that the swarf does not drop into the mechanism.
Do the same to the pins on the camera, also holding it face down also to stop the swarf getting into mechanism. Once they are cleaned off use a can of compressed air and blow out the lens and the camjera ( being carful not to blow too hard on/around the mirror
Remount the lens and ...happy days!
Please rate our help to keep the FREE service online++++Thanks for usimg FIXYA
9/9/2009 12:01:51 PM • Canon EOS-1Ds... • Answered on Sep 09, 2009
Necesito manual de instruciones en idioma espanol...
Ebay tiene una aqui.
Es solo $5...
Buena Suerte!
K
5/18/2009 4:22:32 AM • Canon EOS-1Ds... • Answered on May 18, 2009
2answers
Under normal sunny condtions at
well ur problem is not clear there is not enough info. camera name model etc. Sandy
5/2/2009 10:12:34 AM • Canon EOS-1Ds... • Answered on May 02, 2009
2answers
SD card not registering
use only the specified or recommended cf cards, I know ultra fast is not compatible to digicam two or more years older models.
4/20/2009 7:43:43 PM • Canon EOS-1Ds... • Answered on Apr 20, 2009
Canon EOS-1Ds Mark II Digital Camera Logo
32 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Eos Canon
  • Eos Canon
Most Popular Question
getting 39 m er 2
  • Cameras
