20 Most Recent
Casio Exilim Pro EX-P505 Digital Camera Questions & Answers
Casio Exilim EX-P505 the left arrow key doesn't work. is it setting or broken? what should i do?
Most likely the arrow key switch is broken or the contacts are corroded. If it's a snap-button switch, it needs to be replaced. If this is bad, I recommend replacing the others also. If it's a conductive rubber button (like most TV remote controls), the conductive patch on the inside is worn and needs to be repainted with carbon/silver conductive paint. A miniature snap-button switch is generally less than a dollar from Mouser Electronics - soldering skills are required for replacement. Conductive paint for rubber button switches is $10.45 for a 1 gram tube. It has a very limited shelf life once it's opened, so use up the rest on the other camera buttons, and the power, channel and volume buttons on your favorite TV remote control (if you can get it apart without breaking the case)
Cameras are typically difficult to take apart for repair. You'll have to consider the value of the camera versus the effort to get to the control buttons. The electronics inside are sensitive to static electricity damage, so you should work on an anti-static mat and use an anti-static wristband with it..
I have a casio EX-505. 2006? Works beautifully
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Possible deleted pictures on my casio ex-p505.
Hello
Please download Disc Digger HERE.
This is a free tool you can use that works very well and there is no
installation required, just run the program once you downloaded it.
Once
you have connected the memory card to the computer via either the
camera or preferably with a usb card reader , run the program.
On
the program , select the dig deep option for accidentaly deleted files
or dig deeper for a formatted card. Then select the card you want to do
the recovery on and run the program.
The data will be displayed
and you can recover it from there. This will only work if the card has
not been used since the pictures were lost. Save the files to a location
on the computer hard drive and not back to the memory card as this will
overwrite the other pictures that still needs to be recovered.
Some of the properties of the files may become lost in the recovery but the pictures should be fine.
Feel free to ask if you need more assistance.
Kind Regards
Andrea
Instructions on operation
support.casio.com > Support > Manuals
CasioIn order to use this service to download user's guides and operating instructions (manuals), you must agree to be bound by the following "Terms and Conditions.
0perating instruction
support.
casio.com/en/manual/009/qw5410.pdf
CasioThis User's Guide uses numbers shown above to identify watch hands and ..... follow the instructions in this manual, especially the information under "Operating ...
How do i unlock the card on my exilim.casio camera
Remove the card and see if the pictures remain on the camera. If they do, then they are stored in camera memory. Make sure the memory lock on the card is in the proper position. Put the card back into your computer and delete the pictures. Then format the card, and try the card again. If the card is still locked, try a different memory card that has been formatted.
Will not upload to mac
To upload pictures to a PC or a MAC, you need to install the software that came with the camera. Only then the computer knows when the camera is connected and can start transferring pictures.
On the CD are also the drivers if your system needs one.
Most brands doe have the software on their site. For that goto the Support part of that site.
