20 Most Recent NEC PowerMate eco PC Desktop Questions & Answers
Nec utow-sun drivers
8/8/2014 12:23:12 AM • NEC PowerMate... • Answered on Aug 08, 2014
Where do i connect my camcorder to my desktop
You might try an IEEE 1394 firewire - usb adapter or cable adapter.
2/25/2012 12:47:31 PM • NEC PowerMate... • Answered on Feb 25, 2012
Sound driver
Hi Sweta, It seems that u didnt install any audio driver for your desktop.Plz download the sound driver from the below links:http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Nec-PowerMate-CT-Convertible-i820-Chipset-Sound-Blaster-driver-113.shtmlor from this linkhttp://support.necam.com/Drivers/?m=434
12/15/2011 2:25:20 PM • NEC PowerMate... • Answered on Dec 15, 2011
The CPU is running and all devices working too but
What's the CPU running?  Did nothing ever display on the monitor since you powered up?  In that case, your display adapter (a.k.a. videocard) is looking suspect; maybe its output transistors got blown.  Find a slot for video and put a card in there and try again....
5/18/2010 8:28:51 AM • NEC PowerMate... • Answered on May 18, 2010
Hi , I have a Powermate Eco and after moving house
There might be a fault with the power supply. Take it to your local computer repair shop and they will be more than happy to test it for you for free.
12/18/2009 10:06:08 PM • NEC PowerMate... • Answered on Dec 18, 2009
Sound
Make sure the drivers are installed for the sound card.
Does it have built in speakers or do you need external ones?
Make sure all connections are in the right place too.
5/24/2009 3:23:12 PM • NEC PowerMate... • Answered on May 24, 2009
Hard crash, Need To Replace BIOS
If you're not good at sodering I'd suggest replacing the whole motherboard. Otherwise go Here <<< for a guide on the bios, and how to replace it.
4/30/2009 1:13:09 AM • NEC PowerMate... • Answered on Apr 30, 2009
Powermate Eco Hard Drive Crashed
Hello
instructions on how to remove and replace the hard drive are on this PDF document.
http://support.necam.com/mobilesolutions/hardware/Desktops/eco/819-201002-000med.pdf
You will need a pdf reader to open the document, if you are unable to open it download a pdf reader here
http://www.adobe.com/products/reader/
Can you remove the hard drive from the computer, write down the details that read on top of it, and also if you could look at the connectors and tell me the details so I can make sure I direct you at a proper replacement.
Thank you,
Ekse
4/27/2009 2:31:39 PM • NEC PowerMate... • Answered on Apr 27, 2009
Nec projector me423w turning off randomly
Check the Eco Mode Page 38 and Standby Mode Page 37 settings in user manual. See also page 90 troubleshooting of user manual ME403U_manual_ENG.pdf (sharp-nec-displays.com)
1/1/2024 8:22:42 PM • NEC Computers &... • Answered on Jan 01, 2024
2answers
What software or cords do I need to get/run in order to get files to transfer to/from the NEC Mobilepro 770, or even get internet?
The NEC Mobilepro 770 is a legacy device that was released in the early 2000s and uses Windows CE as its operating system. Since the device is no longer supported, it may be challenging to find software and drivers that are compatible with modern operating systems like Windows 10. Here are some steps you can take to transfer files and connect to the internet:
  1. Get the necessary cables: You'll need a USB cable to connect the Mobilepro 770 to your Windows 10 PC. The cable should have a USB Type-A connector on one end and a mini-USB connector on the other.
  2. Install ActiveSync: ActiveSync is software that allows you to synchronize files between your Mobilepro 770 and your PC. Unfortunately, ActiveSync is no longer available for download from Microsoft, but you may be able to find an archived version of the software on the internet. Install ActiveSync on your Windows 10 PC and connect your Mobilepro 770 to your PC using the USB cable. If the device is recognized, you should be able to transfer files between the two devices.
  3. Connect to the internet: The Mobilepro 770 has a built-in Ethernet port that you can use to connect to a wired network. To connect to the internet, you'll need an Ethernet cable and a wired network connection. Plug one end of the Ethernet cable into the Mobilepro 770's Ethernet port and the other end into your router or modem. You should be able to browse the internet using the Mobilepro 770's built-in web browser.
  4. Install additional software: The Mobilepro 770 comes with a basic set of software, but you may want to install additional software to make the device more useful. You can download and install software from the internet, but make sure it's compatible with Windows CE and the Mobilepro 770.
Keep in mind that the Mobilepro 770 is a legacy device, and its performance and capabilities may be limited compared to modern devices. It's also possible that some of the software and drivers you need may no longer be available or supported.
10/7/2023 6:36:01 PM • NEC Computers &... • Answered on Oct 07, 2023
How to view files from old NEC versa 4050c. hard drive op-220-62005
They don't make them like that any more! The Service Manual lists it as a standard IDE drive. Your best bet is to take it to a local computer shop. They can remove the drive and add it to a test bench set up, then transfer all the data to a pen drive as the hard drive is only 2.1 Gb. https://www.manualslib.com/manual/366990/Nec-Versa-4000.html?page=42&term=hard+drive&selected=3#manual Or use the power supply from another old computer, as the connector plugs should be the same, 12 volt and 5 volt. Or get another on eBay NEC Versa 4050c 90mhz Pentium laptop off eBay for $25 shipped. It has a 2.1gb drive, 40mb of ram. It came with a docking station. https://www.google.com/search?q=NEC+versa+4050c https://www.google.com/search?q=nec+versa+4050c+transfer+data+to+pc ..
9/9/2023 7:32:18 PM • NEC Computers &... • Answered on Sep 09, 2023
2answers
I have an NEC Multisync LCD4610-BK that I can't get sound output from. I'm trying to use it with a roku device that is plugged in via HMDI to DVI converter. How can i get sound?
DVI video cables don't carry audio. Thus you need to use an audio extractor or converter instead of just an HDMI to DVI adapter cable. Try something like this: https://www.amazon.com/J-Tech-Digital-Extractor-Converter-JTDAT5CH/dp/B00BIQER0E/ref=psdc_280341_t1_B01MQYTUAK . Then connect the HDMI to DVI cable to the HDMI out of the converter. Then the audio out to one of the audio connections on the LCD4610-BK. Note: this converter requires you to get the extra HDMI and audio cables separately. Depending on your ROKU device, you might need an HDMI (F to M) adapter to ensure that you aren't blocking other things on the front of the converter. Then set the monitor to the appropriate video and audio inputs separately. I hope this helps. Cindy Wells
6/14/2023 6:41:32 PM • NEC Computers &... • Answered on Jun 14, 2023
How do I change the time on NEC Dterm Seriesi So far I have pressed feature 4, Feature 9 then #
There is a post here: https://sundance-communications.com/forum/ubbthreads.php/ubb/showflat/Number/242170/Searchpage/2/Main/42698/Words/time/Search/true/time-change-this-weekend#Post242170SV8100 and IPKII systemsFrom any display phoneWith the phone hung up to endCheers from Atcomhttps://atcomsystems.ca
4/18/2023 8:52:30 PM • NEC Computers &... • Answered on Apr 18, 2023
Anytime I switch on my NEC laptop, it takes time to load and when it does. It turns gray with bios setup options
Hi, Please place the laptop into safe mode and run a virus scan within safe mode to ensure your computer does not have any unwanted threats that might lead to the issue that you're currently experiencing. Thank you.
7/28/2022 9:18:07 PM • NEC Computers &... • Answered on Jul 28, 2022
2answers
NEC Versa LX Screen will not come on
NEC Versa LX Screen no model told screen, a monitor is it"? the 1998 PC that? has no change at all to run zero. Pentium II (p2) relic, no modern OS run on it the coin cell battery and huge battery are toasted. hdd is bad. it has zero value now, and to fix it will be costly . the CCFL back lamps are dead. what is there to like, sure free in a garage sale. zero value. ,try moving from 1998 to 2010 to gain a future.
6/6/2022 5:46:00 PM • NEC Computers &... • Answered on Jun 06, 2022
Computer picture on HDMI Input above its native resolution of 1280 by 800 goes unstable on Nec M362w. Flickers from bottom of screen. Any ideas ??
USA? or where? ours is 60hz only, are you using 50Hz and bought in USA now it fails? dont do that. NEC M362w, connected to what? this is called a Projector. 1280 by 800 is native reso. so that is not a problem. Hz>? 50 or 60 or above>? what Hz./ rate.? OURS only does 60-hz how long is the HDMI cable 6 ft, or 60ft or what? what PC is it connected to. and is it set to 60 HZ or wrong page 146 in the manual covers all those tricking Horz,/vert/refresh rules the projector does this at other rates HDTV (1080p) 60 HDTV (1080i) 60 HDTV (720p) every monitor or projector or PC has limits here and seen here. for proj only. https://www.manualslib.com/manual/711311/Nec-M362w.html?page=157&term=hz&selected=13#manual set PC to 1080P and it will do ether, 50 or 60hz refresh. no PC told, no clues and matters huge.
3/22/2022 12:50:00 PM • NEC Computers &... • Answered on Mar 22, 2022
The sound on my nec versa p8210 is not working.
Try a pair of headphones to see if that part is working.
9/14/2021 1:30:00 PM • NEC Computers &... • Answered on Sep 14, 2021
Flash player 10 download
Hi
You can download the flash player from adobe's website i.e. from this link---
Flash player 10 download link
Alternatively you can download it from----
Adobe flash player 10
Daniel Scott
8/31/2020 3:37:19 AM • NEC Computers &... • Answered on Aug 31, 2020
2answers
I can not play movies
Hi..
AMR (Adaptive Multi Rate) is common audio file format for mobile devices like mobile phones, laptops, portable recorders.. etc.
in fact totem movie player can't play any amr files (files encoded in amr codec) by itself. Totem Player depends on Gstreamer libs, which haves necessary media handling components .
from your post its not clear that whether your totem can't play movie files from the very beginning or just you can not play movies recently.
your totem player may lacks Gstreamer library files or somehow your Gstreamer libs got corrupted recently.
Reinstalling Gstreamer Library file may help you.
you can find latest source version of Gstreamer on this page
(more detailed download of Gstreamer can be found on http://openports.se/multimedia/gstreamer-0.10 )
3/21/2019 11:11:54 AM • NEC Computers &... • Answered on Mar 21, 2019
NEC PowerMate eco PC Desktop Logo
9 questions posted
Top NEC Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NEC Computers & Internet
Most Popular Question
powermate eco hard drive crashed
  • Computers & Internet
