rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions this will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updatedhope this helps
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure the CPU central processing unit has thermal paste and dust free and is securely seated
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps you
78 questions posted
244 Questions
160 Questions
63 Questions
51 Questions
45 Questions
