20 Most Recent
Nokia 6670 Handheld Questions & Answers
Unlock key for Lcg juke box
Get the cracked version of the LCG jukebox.
No need for unlock key.
Get it at
http://teamfluxion.synthasite.com/resources/LCGJukebox.sis
Put '0' as your unlock code if it asks for it.
Enjoy
please Rate me.
Why java is not supporting?
Some java file on your mobile is working,the problem is the application you download might not suitable or compatible in your mobile.
Try to download on this free site :
JAVA SOFTWAREIf still all application is not working,try to reset your mobile by typing *#7370# in your home screen.this will reset your phone to its original default.just make sure that you back up all data of yours cause it will be deleted as soon as the phone restarts.
Also try to scan your memory card with the latest update of anti-virus,it might be infected by virus that's why all files is being corrupted.
Good luck.
Text message
i have the same problem, i cannot text !!!!
i have the Sony Ericsson P1i
i have also tried changing 2 sim cards but still no solution...
Start-up Failed Contact retailer
try this tricks....
If you encounter situation like below on your 6670,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
Do a Full phone formatting on your 6670! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your 6670phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6600 phone.
Remember, do not let go all of the keys and hold keys until you see a NOKIA turns to white screen LCD!
5. After a few minutes when the Full phone formatting completed, your 6670 will back to original system and factory settting.
All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.
but still you have the prob. Contact Re-tailer
go to the Cellphone Shop nearby and try to re-program your mobile or Hardware...
Thank you for rating this Tip.
ULTRA MP3 PERSONAL LICENSE KEY
NOKIA EXPERT
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE
REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
When getting in to memory card for nokia 6670..it
Remove the SD card and check the memory card for a scan on your PC. It is possible that there are bad corrupt files on the card and must be removed and formatted., the reason your phone is hanging up.
Once done remove the battery off from the phone and reset.
My nokia 6670 wont start..pls i need help
Remove your battery.Wait about 30 seconds.
Then follow these steps
1.Insert The battery
2.Press and hold the key combination given below
"Green Key" + " * key" + " 3 key"
3.while holding down those keys press and hold " Power key" until you see regional settings menu appears.
notes
1.Though this is a standard method,I'am not responsible for Any loss of data or any damage caused by doing whatever I mentioned.Do with your own risk.
2.All the keys mentioned above must be press and hold without releasing.
Not boot
my nokia 6670 doesn't boot gives message while power on "phone start-up failed " thnx 4 help
My mobile not work that
This is because you have a software problem.Please go to nearest nokia care they will reinstall the software for you.Then mobile will be fine.
Thank You
My phone had the same problem, network
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
CAMERA NOT WORKING
Make a backup on your PC first,
Eject Memory Card from Phone
Format your Phone,
then Format memory Card through PC
some unnecessary library files in your memory card cause the camera not work
try this! :)
