20 Most Recent
Nokia 9500 Handheld Questions & Answers
Not able to power on Nokia 9500
Hi There
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Restrict incoming calls for certain numbers and SMS
yes your provider must support this feature. if you are not on contract then it will definately not be available. if you are on contract then give your provider a call and ask them to activate the features you want.
How to Install Nokia MTK USB Serial Port Driver
How To Install Nokia MTK USB Serial Port Driver: Step 1: First Download (WinRAR/ 7-Zip) Software And Install On Your Computer. Step 2: Download Nokia MTK USB Serial Port Driver, Then Right Click And Extract Files On Your Computer. Step 3: Open Nokia MTK USB Serial Port Driver Folder. Step 4: Now Select (Nokia MTK USB Serial Port Driver.exe) And Right Click To Select Run As Administrator. Step 5: And Then Next- Next- Finish. Step 6: Then Restart Your Computer. Step 7: Now Your Nokia MTK USB Serial Port Driver Install Complete.
How can i get my nokia c2-01 from test mode?
To exit test mode, turn off phone.
Press *3001#12345#. Scroll up 1 to FIELD TEST (some phones may say NET MONITOR instead of FIELD TEST) and SELECT. Scroll to ENABLED and press OK. Turn phone off and then back on. Signal strength is the upper or lower left number. After test mode is enabled it will stay in your regular menu. To easily get in or out, press MENU, up 1 FIELD TEST and SELECT or OK. Dial 00 to get out and 01 to get back in.
