Welcome to Fixya
Verify your Windows operating system first is it is a 32 bit version or 64 bit version. Go to: Start-->Right click on Computer or My Computer and select Properties. Look for the System Type. If it says 32bit then all you need to do is download Palm Desktop 6.2.2 (
Download Here) and a 3rd party program from Pimlico Software located here:
http://www.pimlicosoftware.com/, and look for a free program at the bottom of the page called: "PalmHotSyncSetup".
If you have a 64bit OS below is the only two options you have to sync your Palm OS device. If your computer does not have a Bluetooth or IR adaptor be sure to get one that is compatible to the PC you are using.
Now if your handheld has a Bluetooth radio you can hotsync though this and not have to worry if you have a 32bit or 64bit OS. To set this up download Palm Desktop 6.2.2 and then look up this link:
http://kb.palm.com/wps/portal/kb/common/article/49229_en.html. Depending on your PC you may need to buy a Bluetooth dongle or adaptor. Be sure to get one that is compatible with your system.
If you have Infrared connetion. This is for the older handheld that do not have Bluetooth. You will need to have an IR port on your computer or find an IR dongle or adaptor for your PC as well. Once you have one look at this link to see how to set one up:
http://kb.palm.com/wps/portal/kb/common/article/1941_en.html
Let me know for any updates.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
