20 Most Recent Palm Treo 600 Handheld Questions & Answers
2answers
How do I purge contacts from the Treo 600?
Best would be to perform a hard reset. This will delete all your contacts, but also all your other data on your phone as well such as mail, sms, call log, settings etc.
  • Unscrew the tip from your stylus
  • Locate the "RESET" hole on the back of your Treo 600
  • Press and hold the power button on the top of your Treo and then press the reset button with the stylus pin
  • Remove the pin from the reset hole FIRST, and then release the power button.
  • The screen will say "erase all data?", tap the up arrow to answer yes
  • 4/2/2020 4:43:48 AM • Palm Treo 600... • Answered on Apr 02, 2020
    2answers
    HOW DO I FIX THESE ERROR MESSAGES?
    you need to run a inbox repair tool.
    Make sure you close outlook
    Start > My computer > Tools > Folder options > General tab click on show hidden files and folders > Apply ok
    Go to the follow wing location to find scanpst.exe
    if you are using Outlook 2007
    C:\Program Files\Microsoft Office\Office12
    If you using Outlook 2003
    C:\Program Files\Microsoft Office\Office11
    Double click on SCANPST.EXE
    Click on browse go to following locaiton where your pst file as been save
    C:\Documents and Settings\Robyn M. Drothler\Local Settings\Application Data\Microsoft\Outlook\outlook.pst
    Click on start > then click on repair
    11/1/2018 8:46:36 AM • Palm Treo 600... • Answered on Nov 01, 2018
    2answers
    Phone Freezes
    If you mean that the phone hangs for a couple of seconds and then hangs up the call - I think I found your solution - http://www.wombatnation.com/2006/03/fix-for-treo-600-hangs My Treo was doing the same thing - so I just reseated the battery connection and it fixed my problem.
    12/26/2016 3:46:18 AM • Palm Treo 600... • Answered on Dec 26, 2016
    Outlook Express
    You cannot sync treo with Outlook express because of the Outlook express limitations However you can sync with Outlook
    4/29/2015 10:18:15 PM • Palm Treo 600... • Answered on Apr 29, 2015
    0answers
    Battery won't charge
    The issue can be one of 3 things.
    1. the charger doesn't work properly anymore - if possible try another charger. Don't buy a new charger, if possible borrow or take it to someone to test. --- If the phone works with the charger but the battery wont hold charge, then the charger is fine go to 2.
    2. the battery is dead. And would need to be replaced. this is the most likely problem.
    To replace the battery, follow these instructions: http://www.directfix.com/category/_treo_600_battery.html
    you can buy a new battery from http://www.directfix.com/mm5/merchant.mvc?Screen=PROD&Store_Code=GHT&Product_Code=PA1547&Category_Code=_TREO
    if this does not fix the problem then. the problem could be the charger (1) or most likely the mainboard (3)
    3. the phones mainboard is faulty and its unable to charge the battery.
    You could try doing a hard reset, but its unlikely to help, the phone probably needs repairs. (A hard reset will delete everything on your device.)
    to perform a hard reset, if you need instructions please click open this page and follow the steps under treo 600 http://kb.palm.com/wps/portal/kb/common/article/42094_en.html#treo600
    if the problem remains after replacing the battery and trying another charger even and hard reset, then the phone is most likely in need of repair.
    9/21/2010 8:30:59 PM • Palm Treo 600... • Answered on Sep 21, 2010
    "not enough power to activate wireless mode" problem for treo 600
    call to your wireless provider and they will help you turn it on
    9/11/2010 11:45:35 PM • Palm Treo 600... • Answered on Sep 11, 2010
    How to get music playing out of my palm it see the
    Check if your ringer volume is turned to low. Adjustment buttons are at the left side of the phone. Check also Prefs under applications - you can set your tones volume there.
    9/11/2010 11:36:15 PM • Palm Treo 600... • Answered on Sep 11, 2010
    How to adjust the date
    Press the "Home" button on keyboard, go to Prefs, then select 'Date and Time' on upper right dropdown list of your screen.
    9/11/2010 11:24:50 PM • Palm Treo 600... • Answered on Sep 11, 2010
    My TREO 600 touch screen stopped working. It
    Go to applications - preferences - touchscreen. Follow the instructions to calibrate your touchscreen. If it does not work, reset your phone by pressing the small button at the small hole at the back of the phone with a safety pin.
    9/11/2010 11:23:09 PM • Palm Treo 600... • Answered on Sep 11, 2010
    Mp3's
    put them on the sd card from your computer, and then insert the card into the treo.
    9/11/2010 11:16:29 PM • Palm Treo 600... • Answered on Sep 11, 2010
    I try set up phone but stylus does not work on scr...
    Use button and go to tap - settings from menu, then tap your screen. Stylus will work.
    Regards
    Marshal
    Dhaka, Bangladesh
    [email protected]
    5/24/2010 3:35:25 PM • Palm Treo 600... • Answered on May 24, 2010
    2answers
    Touch pad does not work. after
    here are a couple of solutions, try them in order.
    1.start making adjustments inward until the tap is registered and accepted. Once the phone allows you to pass this step, you can try to recalibrate the screen from the preferences.
    2. Do a hard reset, to do this press the "up" button while pressing the "Reset" button
    2/5/2010 6:04:58 AM • Palm Treo 600... • Answered on Feb 05, 2010
    2answers
    Treo 600 Completely Blue Screen
    I's sorry to tell you your screen is dead. The screen is not displaying any information but the backlight is still functioning. This is the most expensive part of the phone as far as replacement parts and after-market parts. If you can fine one that is a reasonable price, you are very fortunate.
    I have three screens like this at home. There are three layers to the screen, the backlight, the imager, and the digitizer. All three sandwiched together create the screen.
    If the phone was on when you fished around the charge port, it is possible that you inadvertently caused a charge or grounded the charging/power circuit. You are fortunate that only the screen was damaged...if that's the only part that is damaged.
    12/17/2009 3:15:54 PM • Palm Treo 600... • Answered on Dec 17, 2009
    How can I shut down the phone. it's constantly on
    http://www.palm.com/us/support/handbooks/treo/treo600gsm_UG.pdf
    Click on the above go to page 14 for turning on and off.
    Hope i`ve helped.
    12/10/2009 7:58:59 AM • Palm Treo 600... • Answered on Dec 10, 2009
    I can receive calls but the caller can't hear me
    Pages 16,38 and 110-113
    Hope i can of been a help to you.
    11/18/2009 11:46:58 AM • Palm Treo 600... • Answered on Nov 18, 2009
    I have a Palm Treo 600. I use Windows Vista 32 64.
    Maybe you can think about to install a Virtual pc whit xp installed just for use whit your phone.
    10/17/2009 7:33:47 AM • Palm Treo 600... • Answered on Oct 17, 2009
    Wireless mode of my treo 600 constantly off
    have you tried to hard reset the unit - backup your personal data before you do
    9/1/2009 8:19:11 PM • Palm Treo 600... • Answered on Sep 01, 2009
    How to unlock a palm treo 6oo
    There are different codes for different service providers. Here are some of them.
    For Sprint, Rogers, Bell or Verizon:
    Your mobile service provider may have set a locking code on your SIM before you received your smartphone. In North America, the default unlocking code is usually 1234 or 1111. You can try these codes, or call your wireless service provider to find out the default locking code they use. Enter the default unlocking code (PIN) and then tap OK. If this doesn't work, contact your mobile service provider to get the unlocking code (PIN) for your acount.
    Caution
    If you enter the unlocking code (PIN) incorrectly three times, your SIM card will be blocked (not locked). If you see the "Unblock Phone" screen instead of the "Unlock Phone" screen, your smartphone has been blocked. You will need to contact your mobile service provider to obtain the unblock code (PUK).
    Extra caution
    If you enter the unblock code incorrectly ten times, your SIM will be permanently disabled. This prevents thieves from running up charges on your wireless account if your smartphone is stolen. If your SIM is permanently disabled, contact your mobile service provider to obtain a new SIM.
    If none of these work then you will need to call your service provider. Best wishes...hope this helps.
    9/1/2009 12:47:19 AM • Palm Treo 600... • Answered on Sep 01, 2009
    Palm Treo 600 Handheld Logo
    Popular Tags
    137 questions posted
    Top Palm Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ADMIN Andrew
    ADMIN Andrew
    vince
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    Treo Palm
    • Treo Palm
    Most Popular Question
    shut down phone s constantly
    • Computers & Internet
