20 Most Recent
Olympus SP-600UZ 12MP 15x OPT Zoom Digital Camera Questions & Answers
Why, when i take a picture and try to see it it comes up with a picture error on my sp-600z camera
The manual says:
Problem with selected image
Use photo retouch software, etc. to view the image on a computer. If the image still cannot be viewed, the image file is corrupted.
But try this. Switch of the camera, remove the battery and memory card. Check if all contacts are clean and shiny. On the battery, on the memory card and in the camera. Then replace the battery and memory card and switch on.
I hope this solves the problem.
Date stamp for Olympus SP-600UZ
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Digital camera problem
I have the serial key for Photoshine v4.2 i.e
Serial: UE@U@322P7B
or
serial : A0JJ8022CFB
Cant transfer pictures from from camera to pc
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
My Olympus VR-340 is not working.
Locate the reset button on your camera, usually found in the battery compartment. Press and hold the reset button for a few seconds, then release it. This action may help resolve any software glitches causing the issue. myreminiapk.com
