20 Most Recent
Cingular Wireless AT&T RIM BLACKBERRY BES V4.0 FOR LOTUS DOMINO - 1U (797553134916) Questions & Answers
I have a user who
Is it just you or any contact for one way chat?
If just you, or just one contact, what I have done is removed that particular contact and real installed with slight name change. Strangely enough vitamin worked for me.
If it's all contacts ( or most) then I would get sim card changed out, I also had that done once before.
Hope this helps
1/15/2018 1:24:14 AM •
Cingular...
Answered
on Jan 15, 2018
On my screen it keeps saying Organizing call logs
Try to reset using the doing these firstly just the soft reset if that doesn't solve the issue complete all these steps.
Perform a soft reset by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys.
The screen will go blank. When the screen is no longer black, press the
ALT+RIGHT SHIFT(CAP)+DELETE keys again. You should then see another
blank screen followed by an hour glass
11/27/2010 8:30:43 AM •
Cingular...
Answered
on Nov 27, 2010
Blackberry messenger will not work
You can try to download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
1/16/2010 8:17:25 AM •
Cingular...
Answered
on Jan 16, 2010
Envelope Notification showing one message
If you call your service provider, they should be able to clear it, provided all messages have been read and you don't have any voicemail waiting to be heard. They can send a "0" count through their switch (processor) to your device which will in turn clear your message waiting indicator.
8/22/2009 1:09:09 AM •
Cingular...
Answered
on Aug 22, 2009
Bb messenger will not open on blackberry storm
heres what i would try.
go to the advanced option in your blackberry device manager, open the .ipd file he has as a backup, then select the file within the .ipd labeled "service books" load only that software and allow it to reboot. then log into your bis email account on a computer and inside your blackberry bis email account there should be a tab call service books, select this to transfer your new service books to your phone and have them reinstall. after that you should be go. be sure to pull the battery afterwards and allow it to completley reboot. if this still does not work check your tcp settings against what your service provider says it should be! please let me know if this works because i have more solutions but it requires a crack to do it and youll need a step by step!
6/24/2009 12:54:49 AM •
Cingular...
Answered
on Jun 24, 2009
My blackberry messenger will not work,
hello
check for these steps
1. options>security options > Firewall> make sure it is disabled.
2. options> security options> general options> make sure content protection is disabled.
3/24/2009 7:00:04 PM •
Cingular...
Answered
on Mar 24, 2009
Instant messenger
both of you download a new version of that instant messenger you are using. that can also be remedied in the preferences tab. look for contacts and show...
7/18/2008 12:59:36 PM •
Cingular...
Answered
on Jul 18, 2008
Blackberry curve 8300
This will help you well. Video instructions just click the link and dont forget my rating. Thanks!!!!
http://www.youtube.com/watch?v=iiIl19G74C0
1/25/2008 9:05:01 AM •
Cingular...
Answered
on Jan 25, 2008
Sim unlock
Contact Cingular if the Sim is locked. Only they can unlock the phone legally IF they locked it. If you locked it and forgot, I would still suggest calling them about it. Doing anything on your own with this problem could void warrenties and insurances you have on the phone. You could also lose service if you do it yourself.
6/18/2007 10:42:02 PM •
Cingular...
Answered
on Jun 18, 2007
I mistakenly moved the windows
Your device needs a complete software reinstallation from scratch. There is no other way to fix it. If you don't have the correct software installation disks (not normally supplied to the user) then the device must go to a service centre.
9/10/2010 10:46:28 AM •
Cingular...
Answered
on Sep 10, 2010
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
