20 Most Recent
PowerBase PB-C125D PB Paper Subwoofers (PBC125D) Car Speaker Questions & Answers
How to wire powerbase speakers to an amp?
your powerbase have's a positive and a negative on the plug the positive is usually red and the negative is black. On your amp find the positive and run a wire to it and conent it to the red on your speaker. Do the sama with the negative conect it to the black one. I hope this helps.
11/4/2009 5:36:49 AM •
PowerBase...
Answered
on Nov 04, 2009
Blown voice coils
Well the voice coil is a basic electromagnet. Electromagnet is a coil of wire, usually wrapped around a piece of magnetic metal, such as iron. there are many things need to keep in mind while replacing the voice coil like - wire size, length, type...... usually the speakers not works good after replacing the voice coils and replacing the speakers is the better option regarding money..... anyway you can please tell us the type or model of your speakers if you need more help or information........
Good Luck!!
Thanks
The high pressure lance has sprung a leak can i
If we're talking about a pressure washer, then yes, you can purchase a new lance. Companies usually sell replacement parts, and there are also after-market parts available. You didn't state the brand or model # of the pressure washer, and depending on the brand and model, you may be able to repair the leak. It may be a matter of a worn O ring. If you purchased the washer locally, go back to the store and ask for a repair kit or O ring (s). They will also have lances as well.
Was this helpful?
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
