20 Most Recent
Samsung Galaxy YP-G70CWY 8 GB White Flash Portable Media Player - YP-G Questions & Answers
Forgot my samsung i9300 phone lock
This may depending on your Android version; I'd suggest trying the following ...
OPTION 1
If you fail to unlock with pattern 5 times, you may be prompted for a backup PIN (hopefully you know that) or a "Forgot Pattern" button will appear. The forgot pattern button will ask for your google email & password; follow the prompts to gain access to your phone & create a new pattern.
OPTION 2
If you have a custom recovery installed or USB debugging enabled, there are instructions here:
Android Guide Hacking And Bypassing Android Password Pattern Face PI
OPTION 3
Failing the above, you may have to do a factory reset. You'll lose any data/apps/accounts on your phone, but at least you can use it again. This method is detailed in method 2 here:
How to Reset Your Android Phone
Reset forgotten password
Go to the samsung website and click on the support tab and look for reset pin. you can also go to settings and security and reset pin code from there as well, if that doesnt work you can always go to security as stated above and click on master reset, just let me know if you need anymore help.
My Samsung Es90 digital camera's shutter is not working, plus, the batteries are fully charged but when inserted, it only last 2-3 minutes. What can I do to resolve this?
I'm assuming by "shutter" you're referring to the one inside the camera and not the cover blades on the very front of the lens.
How old is the battery and do you use the camera a lot?
Old batteries can be fully charged but can become weak and not hold that charge when the camera is powered on. The shutter issue could be part of this as the battery might not be strong enough to power the shutter.
I think the batteries for these cameras are reasonably cheap so you could invest in a new one to see if that helps. An extra battery is always useful if you use the camera a lot.
If this is an old, well used camera part do wear out so if new battery doesn't help you may need to take it to a good repairer as the camera will need to be taken apart to find the problem.
Samsung Digimax 301 will not turn on only green light flashes
- Check battery polarity: Ensure that you have inserted the AA batteries correctly, aligning the positive (+) and negative (-) ends as indicated by the camera's battery compartment. Improper battery placement can prevent the camera from powering on.
- Clean battery contacts: Over time, battery contacts can accumulate dirt or corrosion, hindering proper electrical connections. Use a clean, dry cloth or a cotton swab dipped in rubbing alcohol to gently clean the battery contacts inside the camera's battery compartment. Make sure to let the contacts dry before reinserting the batteries.
- Replace batteries: Even though you inserted fresh AA batteries, it's possible that they may not have sufficient power to operate the camera. Try using a different set of new batteries or fully charged rechargeable batteries to eliminate the possibility of a power issue.
- Reset camera settings: Some cameras have a reset option that restores the default settings, which can help resolve certain issues. Look for a small reset button or a menu option within the camera's settings to perform a reset. Refer to the camera's user manual for specific instructions on how to reset your Samsung Digimax 301 model.
- Firmware update: If your camera has an outdated firmware version, it may cause compatibility issues or malfunctions. Check the Samsung website or contact their support to see if there are any firmware updates available for your camera model. Follow the provided instructions to update the firmware if necessary.
Why is my pl90 samsung digital camera saying that i have the memory card in erong when its in right
Try this. First try another memory card. This will help work out if it is a camera or a memory card issue. Remove the card and take a very close look at the metal contacts on it. Your looking for dirt or damage like scratches or missing metal.
Next using a light, look inside the slot the card fits into for loose dirt or lint.
Connect the memory card to your computer/laptop and check the card registers on there. You could also try re-formatting the card to clear it and reset it to factory level.
Can't find my software for digimax 240 where can I get?
will my digimax 240 work with my laptop windows8
WHAT STOPPED YOU FROM TRYING
the Pc must be internet connect for w8 PnP plug and play to work
the CAM< came new with the SOFTWARE driver, on CD
lost the CD but wait it only does windows XP max. on disk
the only manuals and drivers are here at the makers web site
UK (guessed)
https://www.samsung.com/uk/support/model/EC-D240ZSBA/E1/
2008 time stamped proves Vista max if at all. USB driver.
the manual too is there.
this cam first sold is 2002
20 years ago., pause for effect.
