20 Most Recent
Ricoh Aficio AP610N Laser Printer Questions & Answers
When I send a 2
THE PRINTER AND THE COMPUTER NEED TO MATCH THE PAPER SETTINGS CHANGE THE SETTINGS ON THE PRINTER AND TYPE..WHEN PRINTING YOUSE THE SAME SETTINGS AS YOUR PRINTING
RICOH AP610n Factory Reset
press the counter key and then press and hold the # key and tap on system settings on the screen . it will ask if you want to reset the machine to factory mode, select yes and wait for the machine to reboot.
thanks and all the best.\
for further clarification, call +233243494871
Codigo de error SC320
poligune moter error
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
It gives a code sc 542
The error code is related to the fuser area.
Likely to be a low fuser temp issue.
Need to verify good or bad heat lamps.
1) Check each lamp in fuser.
(lamp is good if you get continuity)
(lamp is bad if open)
2) Check the thermostat. (thermal control device)
(triggers if unit gets too hot)
3) Also check thermistor (monitors temp of fuser)
(2) total (middle and rear)
If heat lamp is good:
Your best bet is to change all three items. (Temp fix)
Fuser thermostat - thermal control device
Fuser thermistor (middle front) - thermal control device
Fuser thermistor (rear) - thermal control device
These items wear out. Change at the same time.
Fuser needs to be rebuilt or replaced.
