20 Most Recent Yukon 4x50 mm Spirit Night Vision Monocular Questions & Answers
Hello, don't worry about it. It is HV to the image intensifier tube. The battery voltage goes through control circuit then to ccfl inverter (here is were dc voltage is switch on and off and switch dc voltage is step up by toroid coil that has two input and only two out puts). By impulsing the coil with two different switch dc voltage on the input this make the current lag the two different phase voltage by 90 degrees. Here is where the strange noise is coming from. The toroid coil is encased in iron case and if half of this iron case is loose, it makes case vibrate so the noise.
Now, the voltage come out of the toroid coil is switching dc (one could call it AC because that what AC voltage is, it switch between positive to negative) this voltage is about 300 to 900 switching DC voltage. This voltage will be applied to a 1/2 wave voltage multiplier (this voltage multiplier with have anywhere four four stages to 10 stages depend on what the input voltage to multiplier is.
Low the voltage out of the ccfl inverter the more stages the multiplier will have.
Now, the voltage multiplier will double the voltage per stage to need image intensifier tube voltage of 12000 to 45000 volts---DC switching or AC what ever one wants to call it. This voltage will bit you but it doesn't have a lot current associated with it, the current would be in the 10 to 15 ua (micro-amps) 1/10X6 amps.
Now, you know. GB...stewbison
Yukon Optics | Answered on Sep 24, 2011
ASK Google OR BUY A RELOADING MANUAL
Optics | Answered on May 01, 2019
Value depends on its condition and and type (upright, baby grand, full grand etc.)
Serial number suggests around the year 1900 but certainly before 1910
Optics | Answered on Apr 29, 2019
Request the information directly from H & R.
Optics | Answered on Apr 27, 2019
Read the Manual:
https://www.searspartsdirect.com/manual/5xg2yzqg8w-001198
Optics | Answered on Apr 24, 2019
check and see if you see an "M" in the display....if so hold down the mode button for at least 5 seconds and change it back to "Y" yards.....try and rate.
mtg
Optics | Answered on Apr 23, 2019
Yukon 4x50 mm Spirit Night Vision Monocular Logo
0 questions posted
Top Yukon Optics Experts
Marvin
Marvin
John Porter
Bill Boyd
Are you a Yukon Optic Expert? Answer questions, earn points and help others
View Most Popular
Yukon Optics
  • Yukon Optics
Most Popular Question
green light comes but no picture best
  • Optics
