20 Most Recent
Samsung SM-352F CD-RW/DVD-ROM (Combo) Burner Questions & Answers
Decoder missing, can't play dvd
Your DVD drive should have included a dvd playing software, such as WinDVD or PowerDVD. If it didn't, you may need to purchase one of these or install the Elecard DVD Codec for free. This link may work:
http://fileforum.betanews.com/detail/Elecard_MPEG_Player/1016751417/1
I cant write data or
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Sadly I cant identify a
Optical drives never require a driver when used in any Windows OS from Win95 and up. Windows XP provides native support that allows this drive to read a data or music disc and or burn a CD-R disc.
Looking driver for dvd rom
If i put in a cd, it doesnt load or install
Please check if the CD/DVD driver is installed properly:
To check:
1. Click Start - Right-click My Computer Choose Properties
2. Click Hardware then Device manager
3. Check if there is a yellow question mark on CD/DVD
If Yes - Reinstall CD/DVD using WINDOWS UPDATE
Alternative:
1. Try to check for loose connection between your IDE cable and IDE Socket
2. Check if the 12V Cord from the Power supply is properly connected to device
3. Check MASTER or SLAVE setting:
Normally the IDE Hard disk will be your PRIMARY and the CD/DVD will be your secondary/slave -----
MORE DETAILS ARE DESCRIBE THOROUGHLY IN THIS SITE:
http://www.ehow.com/video_4444761_setting-pins-cd_dvd-hard-drives.html
Please Rate. Thanks.Cheers!
Samsung 352F CDRW/DVD ROM doesn't recognize DVD-R discs
Which operating system of Windows are you using to burn them?
If you are using Windows XP you will need a program such as Nero to burn them. The send to DVD doesn't work in XP. It will only work on Cds. One should have came with the DVD.
