20 Most Recent
Samsung V20 XVC 2400 Notebook Questions & Answers
Will not start up
Check battery charge. Alot of computers have a problem with holding a charge even to the point of not being able to turn on. If it still doesnt start with it plugged in and you know its not the charger (try with other chargers if available) you may need a new battery. Has it turned on in the past? If you use it alot on the internet with downloading, you could also have downloaded a virus.
SAMSUNG V20 SCREEN WONT RESPOND
I have come across this issue before. I believe it was with a dell or Gateway laptop. The screen had been stepped on. I wanted to check the computer out before I replaced the screen. I connected an external desktop monitor. It worked fine. You just have to hope that the dual monitor feature is enabled. There's no way to do it without a monitor or active screen. I hope that helps.
Samsung v20 disassembly
After removing the screws, lift the keypad by releasing the two latches just below the ALT key and WINDOWS key. Two more screws are hidden beneath the keyboard. Hope this helps
Hi all
i have an Samsung
I checked previous solutions provided here for this fault and found the following
http://www.fixya.com/support/t3821432-start_samsung_v20_up_all_get_blank
Please read all the way through first.
I don't enable wireless. Wireless
there is a button on the side or top i cant remember on this model for wireless to be on or off. if you see no wireless networks then it set to off it may be a slide button on the side as well . also check your keyboard if you see what looks like the letter i with circles around it hold the fn key an dpress that key it wil turn on your wireless.
How to boost your pc memory
It all depends on what you mean by boost. I would recommend just buying better/more ram with a better CAS latency and/or speed then the current RAM you have to the fastest compatible RAM for your system. If you need further assistance please let me know and please confirm the model number of your laptop.
Thank you,
Lee
When i try to get my internet it says my wireless
There is a switch for the wireless internet on the outside of the computer, its small and has the wifi logo near it, look carefully you may have turned it off accidentally.
Thanks
Adam
please leave me some feedback
Iam selling the computer and
the are programs to do a government wipe they will wipe it 7 times. i believe there are some free ware that will do the job. pcworld.com will have a list of both freeware and for pay.
