20 Most Recent
Samsung ML 1210 Laser Printer Questions & Answers
Gavran
Please visit http://www.samsung.com/us/support/search/supportSearchResult.do?group=printersmultifunction&group_cd=&type=printersmultifunction&type_cd=06010000&subtype=monochromelaserprinters&subtype_cd=06010400&model_nm=ML-1210&dType=D&vType=&mType=&model_cd=&menu=%2Fsupport%2Fsearch%2FsupportSearchResult.do&prd_ia_cd=06010400&acc_ia_fl=N&disp_nm=ML-1210&isEqualsY=
If you need to search Samsung.com for the printer drivers, type in "ML-1210" under the model number.
Hope this helps!
Data light
I have the same problem. did you find the solution???
Who is Open Fuser error
The fuser is the last stage of the printing process - it's what "fuses" or basically bakes the toner into the paper. It's a hollow metal tube with a heater element inside it - that element (lamp) has to reach normal temperature or it will give you that error. Could be the lamp itself burned out or could also be an electrical problem in that circuit. Requires a technician to replace the lamp.
I need download driver software
Please go to this link http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=ML-1210.
Scroll down.
Under Products Support please click Universal Print Driver.
Scroll down a bit.
Under Downloads select your operating system.
Hope this helps.
Thanks
Hi All,
I have ML-1210
to solve your problem you need the USB to Parallel adapter. Find examples here:
http://www.google.hr/#hl=hr&source=hp&q=usb+to+parallel+adapter&oq=usb+to+para&aq=1&aqi=g10&aql=&gs_sm=e&gs_upl=1146l3721l0l11l10l0l3l3l0l240l1191l0.4.3&fp=92b2044ee890eadb&biw=1366&bih=611
Regarding drivers, if you dont find for Win 7 try from XP.
Hope that helps!
HI how easy is it to fit a new toner
There is no problem if you have a new cartridge - just open the printer, pull an old cartridge and insert a new one (follow the instructions, provided with new cartridge)
But if you want to refill an old cartridge - you'll need to disassemble it, clean with service vacuum, fill with new toner and reassemble the cartridge. So it requires some skills.
Driver for w7
Copy the link below and paste it onto the address bar. Download and install it after.
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=US&CttFileID=2305398&CDCttType=DR&ModelType=C&ModelName=ML-1210&VPath=DR/201011/20101115101918937/Samsung_Universal_Print_Driver.exe
If you're having difficulties, go to http://www.samsung.com/us/support/downloads/ML-1210 and click on the universal printer driver.
How to reset samsung ML1210?
- Turn the printer off by pushing the power button in until the LED light
turns off. Make sure the printer is off before proceeding.
- Remove the power cord from the back of the printer. Leave the printer
unplugged for at least five to 10 minutes.
- Plug the printer back in. Press and hold the stop button for two to
three seconds until the demo page begins to print.
Hope it works...
