20 Most Recent
Samsung ML2250 Laser Printer Questions & Answers
My Samsung ml-2250 printer won't turn on. Are
I have this problem many times with this model. There are NO damaged fuses. Power supply board is defective. I think that there is nothing you can do in this case! Sorry:(
pifonski
Ml 2250 el led esta
Sorry no habla el espanol
Check the paper tray. There's a latch along the lower left edge that's supposed to let the paper pop up when the tray is inserted so it can feed. If the tray looks OK, check the paper path again and look for a torn off piece of something in there. All it takes is one little piece of paper jammed in there to make the light come on. Use a flashlight and try blowing some air through it with the tray out, back door open and cartridge removed.
Rob
Thanks for ratings.
Online error
problem with Samsung ML2250 laser printer when power on the printer it is blinking green light after few second red light is blinking what is the problem. i am changing the fuser & toner also when i got same problem please help me to give better solution.
My Samsung ML-2250 printer sounds
Hi ,
kindly Open His Cartage Cover , And try to have a look in Imagining Unit , I think Its not fixed Properly.
Shahzad Rashid
IT Hardware/Software Engineer
